I just installed the local help (downloaded the exe from knowledge.autodesk.com site) in the default directory, but when I go for help, it opens the web page online http://help.autodesk.com/view/NINCAD/2018/ENU/
How can I make it open the local help installed in the PC?
Edit
Just found the option to "activate" the olocal help, thanks
Solved by Michael.Puschner. Go to Solution.
Just installed NINCAD2019, and it's the same: is there a way to open local help from within NINCAD?
Did you change the Help Options in the Default Settings?
More about it here:
http://help.autodesk.com/view/NINCAD/2018/ENU/?guid=GUID-1B07B8F6-61E0-46F6-8E3D-CAEC76EBECA7
