The load arrows are not staying attached to the surface / edge when showing a deflected result. This was an issue previously but I thought it had been corrected....
Solved by Andrew.Sartorelli. Go to Solution.
Hi Richard,
I'm seeing this as well. I'll send a quick note to the development team.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Hi Richard,
I checked on this issue, it appears this feature has been disabled due to some performance issues that were occuring.
Andrew
Thanks for checking - hopefully they can sort this soon as the deflection output load arrows not attached looks poor. I have noticed that this behaviour also applies to remote loads - not great if you want to show a customer....
Is the load arrows not being attached likely to be addressed anytime soon?
