Question: Where can I find a list of the latest Autodesk Knowledge Network support solutions that were created and/or updated for Nastran-in-CAD?
(List appears in chronological order)
ARCHIVE
March 2016
Choosing different solver to reduce runtime in Nastran In-CAD
April 2016
Error: “FATAL ERROR S1117: INTERNAL ERROR DETECTED IN MODULE” in Autodesk Nastran In-CAD
Nastran In-CAD 2017 support for Solidworks
Warning T2061: Unreasonable Material Data
May 2016
Fatal Error T2135 when running impact analysis
Product Deployment 2017 - How To fix a User License Deployment that was installed incorrectly
June 2016
Available of cloud solvers for Nastran In-CAD
Contact stresses localized to single nodes for cylindrical contact
FATAL ERROR T2010: ID OUT OF ALLOWABLE RANGE (1-99999999) in Autodesk Nastran
Model with sketch plane fails to mesh in Nastran In-CAD
Nastran 2017 installer doesn’t have the Create Deployment option
Unable to obtain convergence when using non-linear materials in Nastran In-CAD
Unable to generate reports for normal modes analysis in Nastran In-CAD
Unconstrained parts influencing random response analysis in Nastran In-CAD
July 2016
Default orientation for composite elements in Nastran In-CAD
How to set output interval based on event time rather than time-step in Nastran In-CAD
How to obtain plastic deformation results in Nastran In-CAD
How to run a random response analysis with no outside loads in Nastran In-CAD
Overlapping geometry causes meshing to fail in Nastran In-CAD
Multi-axial fatigue results appear incorrect in Nastran In-CAD
What is the difference between animate and multi-set animate in Nastran In-CAD?
August 2016
Does Nastran In-CAD have an automatic mesh convergence function?
Error: “T2260 Insufficient element storage space allocated” in Nastran In-CAD
FATAL ERROR E5000: SINGULARITY DETECTED in Nastran In-CAD
How to represent 2D solid elements in Nastran In-CAD
Is there a load combination tool built into Nastran In-CAD?
Selecting part view in Nastran In-CAD causes Inventor to crash
T2217 warnings about SQUAD keep occuring until Nastran In-CAD crashes
Transferring stress state between load cases in Nastran In-CAD
September 2016
Error: “Could not find a valid FE Mesh. Please generate FE mesh!” in Nastran In-CAD
How to determine the critical speed of a rotating shaft in Nastran In-CAD
October - November 2016
Is it possible to get the total reaction forces per increment in Nastran In-CAD
The fatigue results in Nastran In-CAD do not match the hand calculations
The life contour for elements in compression is wrong for Nastran In-CAD fatigue analysis
The stress concentration factor KF is ignored in a Nastran In-CAD fatigue analysis
Shell X-Normal and Y-Normal Stress results are wrong in Autodesk Nastran In-CAD
December 2016
Assembly or part fails to mesh in Nastran In-CAD
Load dialog box shows wrong units in Nastran In-CAD
