Hi all.
I am Marcelo Miranda and I work in Zodiac Aerospace, Brazil Facility, in Stress Department.
We create the FEM using FEMAP 11.1.2a and use NEi NASTRAN as solver of our analysis.
Since that we have an update in AutoDESK NASTRAN from 2015 to 2016 version, when we try to run the analyze using Hexmeshing Elements, I noted that some elements do not have results in stress.
As you can check in the image, Hexmeshing tools create some wedge elements also, (beyond the Hex/brick elements) and in these elements that we are not finding results in the stress analysis.
We do not know if there's some configuration that maybe could be lost in the software update or something like it.
The people that still have the 2015 version can run the analysis normally, getting results in all elements in the model.
If we create a FEM using TetMeshing, no problems were find after to run the analysis.
Resuming:
So, someone could help us with this issue?
Sincerely,
Marcelo Miranda
Solved by John_Holtz. Go to Solution.
Hi Marcelo,
It sounds like a bug to me, but I will check if there is something else.
Hi Marcelo,
I have confirmed that it was a bug in version 2016. It was fixed in 2017 R1.
Hi John.
Thanks for the answer. I will pass this info for all people in the department.
Have a nice day and once again thank you so much.
Sincerely,
Marcelo Miranda
