Nastran Forum (Read Only)
Welcome to Autodesk’s Nastran Forums. Share your knowledge, ask questions, and explore popular Nastran topics.
Thin Body Cone: Buckling Analysis due to Vacuum
2 REPLIES 2
377 Views, 2 Replies
Hey guys,
I'm having trouble performing a modal linear buckling analysis on a thin body cone. I've set up a pressure load and constrained the edge of the cone.
I'm getting the error E5004 and I've tried the suggested workarounds (http://help.autodesk.com/view/NSTRN/2017/ENU/?guid=GUID-0B6EAC2C-29C2-4AEF-B3FC-91325EE92CD7).
I've attached an image of the setup and the part in question.
I suspect I've set up something wrong with the thin body itself? Any help or solutions would be greatly appreciated!
Kelvin
2 REPLIES 2
shigeaki.k
Hello @Anonymous ,
could you tell us which version of Nastran In-CAD you are using? I am using 2018.2.1.428 and I had no issue running the analysis.
Shigeaki K.
Shigeaki K.
Technical Support Specialist
サポートとラーニング | Support & Learning
shigeaki.k
in reply to: shigeaki.k
Hello @Anonymous ,
if you are using a older version where two subcases appear then the below article might help.
Error: "FATAL ERROR E5004: STIFFNESS MATRIX SINGULAR OR NON-POSITIVE DEFINITE " when performing a buckling analysis in Nastran In-CAD
Shigeaki K.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Shigeaki K.
