Selection by UV shell
Under the  'Select Faces' tool it would be good to have an option to select by UV Shell. This could work in the 3d and UV viewport by pre-highlighting the shell when you mouse over an object. It will be a really quick and clean way to show/hide certain parts of the model to work on.
2 Comments
why not use the select uv shell tool`?
I'm not sure why but I had completley forgot that was a button, I should have checked! My bad.
As a side note though, pre-highlighting the shells would be nice and also to use the same tool in the UV View.
