Stencil strength issue
I have a face and use a stencil image for the wrinkles.
when transfering the wrinkle info, it adds too much height to current mass of the face.
I just want the detail to pass (a little height is ok).
how do I go about solving them issue.
Its_jay
First make sure your stencil is black/white (alpha map) for good results
Two
Try to use (sculpt / wax) brush or something like that
With lower density or different falloff brush
You must get experience with those tools and setting
imre.major
Isn't lowering the brush strength help?
Its_jay
Yes , but work with the other brush and tools may the work easier and
better
I tried to make a stencil off od a pic of a face. using High Pass filter.
but it didnt come out "clean" as in transparent where it should be.
any tips as to how to get it transparent where it should be ?
Its_jay
I highly recommend use Photoshop for creating such a things or something like that but if you don’t have experience you can download it from
http://pixologic.com/zbrush/downloadcenter/alpha/
