Mudbox Forum
Welcome to Autodeskā€™s Mudbox Forums. Share your knowledge, ask questions, and explore popular Mudbox topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Mudbox UV problem/ Maya UV Problem
7 REPLIES 7
Message 1 of 8
922 Views, 7 Replies
Ok so ive come across a problem that I have no clue how to fix. I have a simple polygon that I unfolded in maya and the uvs seem fine as I will provide screenshots, but when I import it into mudbox it shows different uvs as if there were imaginary points floating in space. Ive selected all vertices and deleted them, ive filled holes so i dont know what else i can do. MayaMayaMudboxMudbox
7 REPLIES 7
Message 2 of 8
Its_jay
Try this way
first send your mesh to mudbox
than
export your mesh from maya as .fbx for uv map in mudbox (but leave triangles checkbox off)
after that in mudbox
import uv
Message 3 of 8
in reply to: Its_jay
Thanks for the reply but nothing changed. I dont know which specific
triangles box you are mentioning but i did make sure the "triangulate" box
was unchecked
Message 4 of 8
Its_jay
Or maybe your scene is broken
Try to send your mesh to new scene (in maya)
Than try in mudbox
Message 5 of 8
jill.ramsay
Are you able to send me your scene? I'd be happy to take a look at it: jill.ramsay@autodesk.com.
Message 6 of 8
in reply to: jill.ramsay
Sure thing. Its attached to this message here.
Message 7 of 8
jill.ramsay
Sorry, I'm not seeing the scene file. Can you email it, please? jill.ramsay@autodesk.com.
Message 8 of 8
jill.ramsay
Hi there,
The problem was the nGons in the scene (faces with more than 4 edges). Mudbox doesn't like those, and in general they're a bad idea. Fix those in the Maya scene using the Multi-cut tool or Connect as per the attached image, and you'll be fine.
Jill
