Vicon Stream Device - Change Server Address - Python
maxime-picot
maxime-picot
Hello everyone !
I would like to modify the "Server Address" value of my vicon stream device (of type "ViconSimpleDeviceOptical") in python.
However, I cannot access this value, I cannot find it anywhere, not even in the property list of the device. Is there a way to access and modify this value?
Thanks ! : )
damian.pajda
those settings are saved in txt file
Documents\MB\[mobu version]\config\[PC_Name].ViconOpticalDevice.txt
so maybe some workaround could be modifing this file by python and recreating the device.
maxime-picot
Oh nice thanks you, that help a lot !
Currently, I'm merging a scene that already containt this device, because I don't know how to import it from python.
Do you know how to do it ?
damian.pajda
I just tested it on mobu 2020  and looks like my suggestion is wrong :(.
This code is creating device, but it doesn't get values from that config file:
viconStreamDevice = FBCreateObject( 'Browsing/Templates/Devices', 'Vicon Stream Device', 'Vicon Stream Device' )
FBSystem().Scene.Devices.append( viconStreamDevice )
Getting proper settings from file works only when device is dragged from browser.
I don't have experience in using devices by python...
Quick research on internet shows that others also have similar issue and your solution with merging fbx file is working: https://stackoverflow.com/questions/50497136/set-up-vicon-stream-device-via-python
BTW. there was some update of device functions in Mobu 2023, they even added some sample script showing how to setup Vicon Device. But I haven't tested it yet. If you have Mobu 2023 or later, maybe it would work.
https://help.autodesk.com/view/MOBPRO/2024/ENU/?guid=MotionBuilder_SDK_py_ref_classpyfbsdk_1_1_f_b_d...
# This example shows how to create a Vicon Stream Device (a third-party device), initialize it and add it to the scene:
# Create the Vicon Stream Device
if viconStreamDevice:
    # Initialize the device
    viconStreamDevice.DeviceOperation( kDeviceOperations.kOpInit )
    # Import the device to the current file
    print( 'Vicon Stream Device initialized and added to the scene' )
else:
    print( 'Vicon Stream Device not found' )
maxime-picot
It works for me, thanks you very much !
