Hi! I'm a long-time lurker, first-time poster.
I am trying to create a script that will add a "Zero" key to my selected object.
I have about 10 days of MotionBuilder python experience and I am a bit stuck trying to figure out how to use FBAnimationNode and
FCurve within python.
The supplied examples and google searches are bringing me little help.
Thanks.
解決済! 解決策の投稿を見る。
回答者: jps. 解決策の投稿を見る。
There are several ways to approach the problem.
Setting a key with a value of 0 on the fCurve. This will work like using the Zero Key button in the Keys Controls:
from pyfbsdk import *
def setTRKeyToZero( yourObject, currentTime 😞
yourObject.Translation.SetAnimated(True) # make sure translations are "animatable"
yourObject.Translation.GetAnimationNode().Nodes[0].FCurve.KeyAdd(currentTime,0) #Node[0] is X, [1][ is Y, [2] is Z
yourObject.Translation.GetAnimationNode().Nodes[1].FCurve.KeyAdd(currentTime,0) # the last 0 is the key value
yourObject.Translation.GetAnimationNode().Nodes[2].FCurve.KeyAdd(currentTime,0)
yourObject.Rotation.SetAnimated(True)
yourObject.Rotation.GetAnimationNode().Nodes[0].FCurve.KeyAdd(currentTime,0)
yourObject.Rotation.GetAnimationNode().Nodes[1].FCurve.KeyAdd(currentTime,0)
yourObject.Rotation.GetAnimationNode().Nodes[2].FCurve.KeyAdd(currentTime,0)
lPlayer = FBPlayerControl()
currentTime = lPlayer.GetEditCurrentTime()
selectedModelList = FBModelList()
FBGetSelectedModels( selectedModelList )
for selectedModel in selectedModelList:
setTRKeyToZero( selectedModel, currentTime )
On other way will be to directly move the object and create a key using the transport control:
def zeroTRTransforms( yourObject 😞
yourVector = FBVector3d( 0, 0, 0 )
yourObject.SetVector (yourVector, FBModelTransformationType.kModelTranslation, False) # False for local transform, True(default) for global transform.
yourObject.SetVector (yourVector, FBModelTransformationType.kModelRotation, False)
zeroTRTransforms( selectedModel )
lPlayer.Key()
A symplified version were it's always a local tarnsform.
yourObject.Translation = FBVector3d()
yourObject.Rotation = FBVector3d()
lPlayer.Key()
Sometimes you will need to use FBSystem().Scene.Evaluate() after changing the transforms of an object to make sure current transforms values are updated.
