MotionBuilder Forum
Welcome to Autodesk’s MotionBuilder Forums. Share your knowledge, ask questions, and explore popular MotionBuilder topics.
Playback becomes impossible. MotionBuilder2020
2 ANTWORTEN 2
Nachricht 1 von 3
y-maruyamaYYKXU
150 Aufrufe, 2 Antworten
While working in MotionBuilder2020, all functions related to playback, such as moving the playback buttons, shortcuts, and seek bars, may stop working.
This can be cured by restarting the program, but it is very time-consuming to restart every time it happens.
Does anyone have a solution?
2 ANTWORTEN 2
Nachricht 2 von 3
Hikaru_T
als Antwort auf: y-maruyamaYYKXU
Hi there,
I use MotionBuilder 2020 on Windows and have never encountered such a problem. If you still have the installer for that version, reinstalling the application might solve the issue.
When I find mouse and keyboard controls not working well, I always try to rearrange the application's layout by selecting the menu "Layout" > "Editing". Sometimes, saving the file has improved the freeze. For transport controls, you can delete the window by clicking the top-right button and recreate it from the menu "Window" > "Transport Controls".
If the problem persists after refreshing the UI, unfortunately, restarting MotionBuilder might be the only immediate solution, even though it's time-consuming. Another thing you might try is running MotionBuilder on a different PC to see if the issue is related to your current hardware.
If there's no specific reason to continue using version 2020, it might be beneficial to consider upgrading to a newer version.
Kind regards.
Hikaru T.
Nachricht 3 von 3
y-maruyamaYYKXU
als Antwort auf: Hikaru_T
Thanks for your answer!
Reinstalling, changing the layout and recreating the UI did not solve the problem.
We are also experiencing the same problem on another computer, so we have given up.
One concern I have is that this problem only occurs with data above 30000f, so I think it's some kind of bug.
Due to the nature of the project, I cannot change the software version, so I will continue to deal with the problem by restarting the software.
Thank you.
