Announcements
Motionbuilder 2017 - Quicktime Render codecs issues
I can't seem to render any codec as an .mov except H.264 ; even uncompressed.
I have Quicktime / QTPro installed.
This is problematic because no software recognizes the render format Mobu renders out.
Sample Error Msg:
child process error: -1073741819
Tried activating the Legacy Codecs with Quicktime 7 to see if it helped, and it DID add a lot more compression options, but still can only render as H.264
Rendering uncompressed .AVI created a render where I was seeing 4 "windows" of my render, at an angle, and it was all purple (corrupted). Not rendering with aliasing on, cam resolution is 1280 x 720.
Has this ever been figured out. having the same issue here.
I managed to get it to work with the Animation codec vs h.264.
We had this problem at our company. It was caused by high resolution set in the rendering settings (2560x1440). Switching to standard HD resolution solved the problem.
Cheers!
