How not to merge takes while merging two files in python
I am trying to merge a rig file to an animation file.
However, I want not to merge the takes of the rig file. In GUI, I can just uncheck the takes and merge the file, but I am having problem do the same in python.
I got following code:
#Open animation file first
lFbxOptions = FBFbxOptions(True)
FBApplication().FileOpen(AnimationFile,False,lFbxOptions)
#Setup options for merge
FbxMergeOptions = FBFbxOptions(True)
FbxMergeOptions.SetAll(FBElementAction.kFBElementActionMerge, True);
FBApplication().FileMerge(rigFile, False, FbxMergeOptions)
I got some suggestion in the forum to unselect the takes using following code:
for takeIndex in range( 0, FbxMergeOptions.GetTakeCount() ):
         FbxMergeOptions.SetTakeSelect( takeIndex, False )
But GetTakeCount() is always returning 0.
So what is the correct way to unselect the takes while merging a second file using python script?
Thanks.
It looks like, GetTakeCount is dependent on how FBFbxOption was initialized in the constructor.
I was thinking to merge a 2nd file I would need to initialize using 'True' parameter as True is supposed to used as loading option.
However, it is working if I Init it using False (which is for saving)!
