Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Where is the project I analyzed with Autodesk Moldflow Insight 2021.1 Command Shell saved?
1292909313
1292909313
bernor_mf
@1292909313
If you run runstudy from the same project folder as your .sdy-file, the result files will be stored in same folder path.
If you have Moldflow Synergy UI open, and use runstudy, and you get result from runstudy, the analysis sequence symbols are not filled automatically.
You need to re-open the project for project folder to be scanned, and connect study with results, and fill the analysis sequence symbols.
Berndt
( If my comments are accepted, provide "Kudos" as appreciation. If your request is answered/resolved, please click the "Accept as Solution" button. Thanks.)
How to reopen the item in the project folder you want to scan, connect the study to the results, and fill in the analysis sequence symbols?
bernor_mf
@1292909313
You just need to re-open the project:
In Moldflow Synergy, at top left, big M:
M> Open > Project
Open the project where you have the study.
When open a project like this, it scans automatically.
This assumes you created the study in the same project and results from runstudy is in the project folder.
Berndt
