** WARNING 302105 ** Flow solution failed to converge within the allowed iterations.
kasi2301
kasi2301
Dear All,
I need the suggestion/ recommendation, about this warning,
This case normal injection is running completed, as per schedule.
But sequential  condition injection I face this issue, and analysis is keep on running condition and not completed after 4 or 5 days later also.
need a Solve the running time issue, kindly support me.
Attached log file for reference.
Replies (9)
mppkumar
Hi @kasi2301
Observation:
1) Part volume (186cm3) is very less compared to hot runner volume (2565cm3). this is not the best practice. consult your hot runner supplier.
2) Injection time specified : 4.5s
Hope hot runner itself not filled within 5.14sec or just reaching the hot gate
3)Pressure also very high @ 25% of filling stage : 102MPa
Suggestion:
1)Optimize hot runner design - hope this will solve the issue
2)Try faster filling
M P Pradeep Kumar
If my views / comments acceptable, provide "Kudos" as appreciation, if answers your query, please click the "Accept as Solution"
kasi2301
kasi2301
hello Sir,
Thank you for the valuable suggestion, let me try this option and I'll share the feed back to here.
kasi2301
Dear Sir,
I tired above solution but still not solve that issue.
Kindly share the another possibility.
https://knowledge.autodesk.com/support/moldflow-insight/learn-explore/caas/CloudHelp/cloudhelp/2021/...
mppkumar
Hi @kasi2301
may i know the results of faster filling and optimized hot runner design
also you can try to increase the tolerance, this may reduce results accuracy
M P Pradeep Kumar
kasi2301
Hello @mppkumar
 This method also not working
vasyabc
@kasi2301 : Error might be due to valve gate control using flow front. instead try for valve gate control using specified time.
kasi2301
Let me check that case also , share the feedback asap.
Thank you
kasi2301
Hello @vasyabc ,  I check Valve gate - open specific time also same error ocuur. 😕
