I have selected a node and through vbs code I am creating a beam element on it . That is ok .
But after generation of beam I want to deselect the node through coding
since the user has to do further actions
Can you give me a code which deselects a node
Solved by beth.mollica. Go to Solution.
Hi @Anonymous
Thank you for visiting the Moldflow Insight Forums! I understand that you have selected a node and through vbs code, you are creating a beam element on this node. I also understand that after generating this beam, you would like a code that deselects the the node.
This cannot be done with the current Application Programming Interface. I would, however, encourage you to post this request/idea to our
Moldflow Idea Station. Posting this idea to the Moldflow Idea station allows our Moldflow Product Management team to take this idea into consideration for a future product enhancement. If posted to the Moldflow Idea Station, myself, and other Moldflow users can vote towards your idea also!
