Valve gate trigger “Flow front” INITIALLY OPEN
simulation_experts
simulation_experts
Dear Moldflow users,
I´m in the following case:
I actually try to set some valve gate triggers for a study with to hot gate (one valve trigger per gate) :
  • The first trigger (t1) at gate number 1 has to be initially open and then STOP at a specific node.
  • Then, the second trigger (t2) at gate number 2 should open at a specific node and stay opened until the end of the process.
This works for the second trigger (t2) because when I set the valve gate trigger to “Flow front” I can define a specific node. Moreover, the “Valve gate initial state” turned automatically to “Closed” which means that the trigger is initially CLOSED.
Then, for the first trigger (t1) I can not specified that I would like the trigger to be initially OPEN and then STOP the process to a specific node. This is because the selection option for “Valve gate initial state” is grey and not available.
My questions:
  • Why is the option “Open” for "Valve gate inital state" not available with Flow front? (this option is available with all other valve gate trigger options)
  • Has somebody a solution to STOP a trigger valve with a specific node or is that an idea for the idea station?
Thank you in advance for your help,
Best regards,
Serge Gugelmann - Technik
[email protected]
RICONE GmbH
Trausnitzstraße 8
D-81671 München
harald_goetz
@ Admin: please delete this ...
