Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Valve gate controller assignment - issue in Moldflow 2025
2 ANTWORTEN 2
Nachricht 1 von 3
Adam.Mayes
105 Aufrufe, 2 Antworten
Has anyone else come across an issue in 2025 when assigning valve gate controllers?
Whatever valve gate controller is first in the list of controllers cannot be assigned to to a gate element.
For example the first controller in the list is #1 default valve gate controller. This cannot be assigned to a gate element.
If you create another controller(#2/#3/#4 etc.) you can assign to an element no problem.
I deleted the default #1 controller. Now #2 cannot be assigned. Seems like whatever controller is first in the list cannot be assigned to a gate??
2 ANTWORTEN 2
Nachricht 2 von 3
bernor_mf
als Antwort auf: Adam.Mayes
@Adam.Mayes
Hi Adam,
I experience the same issue using tab Boundary Conditions > Valve Gate Controller > Assign to elements
after creating controllers. The top of list cannot be assigned to element.
The workaround I use is to select gate beam, right-click and Properties, tab Valve Gate Control
Then you could select from list, and top of list.
Believe this is a defect that needs to be fixed.
Berndt
( If my comments are accepted, provide "Kudos" as appreciation. If your request is answered/resolved, please click the "Accept as Solution" button. Thanks.)
Tags (3)
Nachricht 3 von 3
raalteh
yes there is an open issue for this for development to fix.
Thanks @bernor_mf for providing a work around.
Hanno van Raalte,
Product Manager - Injection Molding & Moldflow products
