In vbs I want to check if the runner system is generated
RunnerGen = Synergy.RunnerGenerator() and give the validation as No gates or injection locations were found. Cannot generate runner system.
If the injection location is not selected
Solved by beth.mollica. Go to Solution.
Thank you for visiting the Moldflow Insight Forums!
If I understand your question correctly, you would like to create a vbs script to check if the runner system if generated?
The RunnerGen = Synergy.RunnerGenerator() script that you referenced is actually used to generate a runner system for your model:
Are you seeing a message that states No gates or injection locations were found. Cannot generate runner system?
Thank you,
Beth Mollica
_______________________________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Actually I am automating all the steps so would like this message to be set in vbs msgbox if we do not assign Injection location in mold flow
Therefore wanted to validate the injection location
To confirm, you are using the RunnerGen = Synergy.RunnerGenerator() to generate a runner system for your model, but you would like a message included in the vbs msgbox stating something like "No gates or injection locations were found. Cannot generate runner system” If you do not assign an injection location correct?
If I have captured your request correctly, I would like to do a bit more research to see if this is currently possible, and if not I would suggest you post this idea to our Moldflow Idea Station. You can use this Moldflow Idea station if you have suggestions for the software or its functionality you would like the Moldflow Product Management to consider for future consideration. Myself, and other Moldflow users can vote towards your idea also once posted here!
Beth Mollica
The API command RunnerGen = Synergy.RunnerGenerator() is the command specific to generating a runner system. As such, it needs to know where the injection locations to the cavity are.
If you want to know if an injection location exists than a script would need to be written explicitly for this. There is no direct API call to determine this.
You would need to export the sdy file in ASCII format and extract and analyse the NDBC blocks to find injection locations.
With that being said, one of our scripting exports provided me with the attached text of a script to identify injection nodes!
Please extract it to a file GetInjectionNodes.vbs
'@ DESCRIPTION
'@ Get Injection Nodes
'@ SYNTAX
'@ GetInjectionNodes
'@ PARAMETERS
'@ DEPENDENCIES/LIMITATIONS
'@ 1/. Minimal Error Checking
'@ Author DRA 23/7/2009
'@ AS there is no direct Direct API calls to work with NDBC data
'@ We need to dump the study file in ascii format and read the NDBC data
Option Explicit
SetLocale("en-us")
Dim SynergyGetter, Synergy
On Error Resume Next
Set SynergyGetter = GetObject(CreateObject("WScript.Shell").ExpandEnvironmentSTetngs("%SAInstance%"))
On Error Goto 0
If (Not IsEmpty(SynergyGetter)) Then
Set Synergy = SynergyGetter.GetSASynergy
Else
Set Synergy = CreateObject("Synergy.Synergy")
Dim FS
Set FS = CreateObject("Scripting.FileSystemObject")
Dim StudyDoc
Set StudyDoc = Synergy.StudyDoc
' read the mesh of the current study file
Dim InjectionData
Set InjectionData = New InjectionNodes
InjectionData.ReadInjectionNodes()
If InjectionData.Size() > 0 Then
MsgBox "Injection Node(s) Found: " & InjectionData.Size(), vbInformation,WScript.ScriptName
InjectionData.WriteData()
Else
MsgBox "No Injection Nodes Found", vbInformation,WScript.ScriptName
End if
WScript.Quit(0)
' ---- InjectionNodes class
Class InjectionNodes
Public mNodes()
Private NumNode, mUdmFile
Private Sub Class_Initialize
NumNode = 0
mUdmFile = GetTempFile(".udm")
End Sub
Public Sub ReadInjectionNodes
' Export the ascii udn
Synergy.Project.ExportModel mUdmFile
Dim FS, File, Line, I, ID
Const ForReading = 1
Set File = FS.OpenTextFile(mUdmFile, ForReading)
Line = File.ReadLine
While Not (File.AtEndOfStream)
If InStr(Line, "NDBC{") > 0 Then
If Left(Line,2) <> "//" Then ' Skip comment lines
ProcessNDBC(Line)
End if
Wend
File.Close
FS.DeleteFile mUdmFile
End Sub
Private Function ProcessNDBC(Line)
Dim Words, NodeID, NDBCType
Words = SmartSplit(Line)
NodeID = Words(8)
NDBCType = Words(6)
'40000 Injection location for thermoplastics processes
'40002 Injection location for reactive processes
'40003 Dispensing location
If NDBCType = 40000 Or NDBCType = 40002 Or NDBCType = 40003 Then
NumNode = NumNode + 1
redim Preserve mNodes(NumNode)
mNodes(NumNode-1) = NodeID
End if
End Function
Public Function GetNode(I)
GetNode = 0
If I >= 0 And I <= NumNode-1 Then
GetNode = mNodes(I)
End Function
Public Function Size()
Size= NumNode
End Function
Public Sub WriteData()
Dim II,lStr
lStr = "Injection Node Numbers : "
For II = 0 To NumNode-1
lStr = lStr & mNodes(II) & " "
Next
MsgBox lStr, vbInformation,WScript.ScriptName
End Sub
End Class
' ---- Splits a line into words properly
Function SmartSplit(Str)
Dim lStr
lStr = Str
LStr = Replace(lStr, "{", " ")
lStr = Replace(lStr, "}", " ")
SmartSplit = Split(Trim(lStr))
End Function
' ---- Gets temporary file location
Function GetTempFile(DesiredExtension)
Dim FS, Temp, lName
Const TemporaryFolder = 2
Set Temp = FS.GetSpecialFolder(TemporaryFolder)
lName = ""
While lName = ""
lName = Temp.Path + "\" + FS.GetTempName()
lName = Replace(lName, ".tmp", DesiredExtension)
If FS.FileExists(lName) Then
lName = ""
Wend
GetTempFile = lName
End Function
WScript.Quit
Beth Mollica
Hello @beth.mollica,
I would like to ask, if any alternative solution was found to this problem. In my POV it seams extremely inefficient to export an *.udm file and parse thousands of lines in order to find the single line inside the "NDBC{}" block with the information about the coordinates of injection locations.
To my problem: I need to get the position of the all gates in multiple *.sdy models. However, since the *.udm files I'm working with are in the order of 500MB+, the method suggested here is impracticable. Currently, I'm trying to get the coordinates of every single gate like this:
' Set injection location propery
Const INJ_LOC_PROP = 40000
' Select all Injection Locations
Set PredicateInjLoc = PredicateManager.CreatePropTypePredicate(INJ_LOC_PROP)
Dim InjLoc_Str
Dim InjLocCoord()
Set EntList = MeshEditor.CreateEntityList()
Set InjLoc_Str = EntList.Entity(0)
EntList.SelectFromPredicate PredicateInjLoc
' MsgBox "Num. Inj. Loc " & CStr(EntList.Size)
If EntList.Size = 0 Then
MsgBox "No Injection Location detected.",,"Error"
Else
' Create array to store injection location coordinates
ReDim Preserve InjLocCoord( 2, CInt(EntList.Size)-1)
Dim Coord
For i = 0 To EntList.Size-1
Set Coord = StudyDoc.GetNodeCoord(EntList.Entity(i))
InjLocCoord(0,i) = Coord.X
InjLocCoord(1,i) = Coord.Y
InjLocCoord(2,i) = Coord.Z
MsgBox "InjLoc " & CStr(EntList.Entity(i).ConvertToString()) & " --- X " & CStr(InjLocCoord(0,i)) & " | Y " & CStr(InjLocCoord(1,i)) & " | Z " & CStr(InjLocCoord(2,i))
Next
This unfortunately results in nonsense values for X, Y and Z. Can you please tell me, why an EntList with the correct property ID of a injection location cannot deliver the correct coordinates?
P.S.: I see myself often limited to write scripts, since very little "getters" functions exist. As such, I'm unable to use most of the public member functions. As an example, I' m unable to use the ModeNDBCToXYZ() function, since there is no way to first get the location of a gate.
F. Porcher
PhD Student
Technical University Berlin / BIT GmbH
