@dramaswamy
the kind of jump you see in time is due to intermediate interval, which the are related to result frames.
For a 3D mesh type, the default intervals are:
Filling: 5
Packing: 5
Cooling: 3
To change for 3D Mesh type:
From Process settings wizard:
Advanced options...
Solver parameters ; Edit...
tab Fill+Pack analysis
Intermediate result ; Edit intervals...
Increase this interval value for more frames.
Minimum 10 of each I would say, but more if needed.
Increasing the value will increase the number of animation frames available when animating certain results through time, but will also increase the disk space requirements for the analysis.
To get the wished default settings when creating new studies:
tab Tools:
Click: Databases (with small arrow down).
Select: Edit Default Properties
Select: Thermoplastics injection molding solver parameters defaults (3D)
Change the settings as preferred for new studies.
Exit with OK.
Note: Updating Moldflow Synergy UI will reset settings to default.
Recording a macro of changes, that could be executed after update helps.
Hope this helps.
Berndt
( If my comments are accepted, provide "Kudos" as appreciation. If your request is answered/resolved, please click the "Accept as Solution" button. Thanks.)
