Unable to duplicate .sdy while simulation is running
akshay_pawar6YJN8
akshay_pawar6YJN8
Dear Autodesk moldflow user with latest release of moldflow i think from 2025 & 2026 why the duplicate tab on .sdy is inactive. Please find attached image for reference.
michaelschoenberger2160
sedaEMRHE
Hello @akshay_pawar6YJN8 ,
Check the options in Results tab. If the option of "Duplicate study-include all result files" is enabled, the option of duplicating is unavailable until the completion of simulation. Hope this helps.
Srinivas.
akshay_pawar6YJN8
@sedaEMRHE thanks for the reply. If you can see the attached image the duplicate tab is inactive. I am aware of these option you have mentioned.
vasyabc
@akshay_pawar6YJN8 : try keeping project folder shorter length, or in local drive and proceed for duplicating.
yogeshwari_shindeU3HP6
@akshay_pawar6YJN8 , Duplicate option is only available for complete run study. You can try Ctrl+T  & then select create copy. Your run will continue & new study will be created.
adevadkar
@akshay_pawar6YJN8 ,there is another way to do this using "Save Study AS".
This will Duplicate study.
Thanks & Regards,
Anirudha D.
