SYSTEM
SYSTEM
shrishailesh
Message 1 of 15
SYSTEM
shrishailesh
What should be the maximum system specifications to run the analysis in fastest time ?
We have cases , where in analysis study has elements around 20 lacs + ..
Please share your thoughts
Replies (14)
Message 2 of 15
mppkumar
Hi @shrishailesh
if possible use HPC (linux based server)
if not,
graphics card more than 4GB (preferably NVIDIA)
RAM - 32GB min
Intel Xenon processor or i7 processor
this is should be faster... when the analysis is running try to minimize processor and RAM usage
M P Pradeep Kumar
If my views / comments acceptable, provide "Kudos" as appreciation, if answers your query, please click the "Accept as Solution"
Message 3 of 15
mppkumar
Hi
you can refer the below link for bench marking done by Autodesk
https://knowledge.autodesk.com/support/moldflow-insight/learn-explore/caas/sfdcarticles/sfdcarticles...
Hard disk specification
Understanding CPU utilization
Previous thread on similar topic
https://knowledge.autodesk.com/support/moldflow-insight/troubleshooting/caas/discussion/t5/Moldflow-...
hope all these will be helpful in choosing your configuration
M P Pradeep Kumar
Message 4 of 15
Sanjay_paul
Hello Pradeep Kumar,
I have a 32GB RAM but it has 2x8GB and 1x16GB. Is there will be any problem?
Regards
Sanjay Paul
Message 5 of 15
mppkumar
@Sanjay_paul... you won't be having any issues
M P Pradeep Kumar
Message 6 of 15
Sanjay_paul
Thanks for replying. I have Intel Xeon E3-1230 [email protected] GHz processor, 4GB NVIDIA Quadro K2200 Graphics card and 2TB HDD. My system rating is given below :
Should I include a SSD drive for better performance? If yes, should I buy 256 or 512GB?
Regards
Sanjay Paul
Message 7 of 15
mppkumar
@shrishailesh
Did my post answers your query
M P Pradeep Kumar
Message 8 of 15
mppkumar
Hi @Sanjay_paul
If you could able to afford SSD drive, then you can go towards it and go for 512GB
performance improvement will be there only on very larger models; otherwise it may not be useful.
for more info refer the below link
M P Pradeep Kumar
Message 9 of 15
Hi @shrishailesh
You can check for this Work station Config from HP, Good for Moldflow heavy runs.. You can increase the Ram to 32GB if required.
Message 10 of 15
Hi @Sanjay_paul
Your system config looks good nice processor, I dont think you need to buy an additional SSD..!!! Current config is more than enough for Moldflow.
Message 11 of 15
@Sanjay_paul - May be you can buy if your organisation has more fund to invest to work flawlessly 🙂
Message 12 of 15
Sanjay_paul
Hello @Anonymous
Thanks! If I want the SSD, my company will surely buy it to me. WIll the SSD will increase my computer speed? Now sometimes my computer is slowing down while running simulation and moldflow insight shows not responding for few seconds but it didn't crash. After that it is running with no problem. My previous RAM was 16GB(8GB+8GB) then I add another 16GB but it didn't improve this problem.By mistakenly I brought one 16GB instead of two 8GB. Is this have any effect in not improving my system.?
Regards
Sanjay Paul
Message 13 of 15
shrishailesh
Partially yes !!
Message 14 of 15
shrishailesh
Thank you sir !!
Still it takes higher time for analysis with more than 15-20 lac  elements .
Message 15 of 15
Hi @shrishailesh
Good config!!!  Analysis time will definitely be more with the study has more no.of elements especially more than 18 - 20 lacs elements, will take 5-8hrs to finish the FPW analysis with fiber orientation analysis ON. 32gb ram & 3.6GHz processor are really a good config to work faster without crash than the other config in the market.
Try launch analysis in the night if you have parts with more than 20lacs Tet elements, to avoid long wait time to view the results in daytime.
