Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Synergy Installation
6 REPLIES 6
KlausMüller8028
537 Views, 6 Replies
why can't I install synergy? The license key is ok , I ask for information
Tags (1)
6 REPLIES 6
I have the same problem
csegard
in reply to: KlausMüller8028
have a look at the disk space. You have only 115Mb available.
Tags (2)
KlausMüller8028
in reply to: csegard
Enough memory >150GB is available
csegard
put your cursor on the forbidden icon, it should give infos on why it is not possible to install
KlausMüller8028
Thanks for the tip, says it's already installed. the deinstallation is completed improperly. Now let the computer from the domain admin check for unclean entries
I have now followed these instructions synergy can now be installed!
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Clean-...
