Shear stress in part causing painting defects
Hello Moldflow users,
I have an issue with an ABS part that is being painted after molding. We have large amounts of painting defects which the painter is telling us is from shear stress and we should fill much slower. The part is basically flat, 330mmx255mm(13"x10") and 3mm thick. Tunnel gated into a "D" shaped ejector pin(Not ideal but gate options were very limited.) Original process had nominal melt and tool temps with a 3-4 sec fill time. The "new" process has nominal temps but 11-12 second fill time and produces parts that will paint much better. So it does seem like slower is better(for paint) but this compromises other aspects of the process with large temperature drops at the flow front and also makes it hard to pack out properly(sink/short).
Trying to corelate this to Molflow. Is it really shear stress or something else. The blotchy appearance on the painted part doesn't reflect any visual pattern that shows up in any moldflow result.
The only visual difference in the molded part is a more glossy part when filled faster.
Anyone had any experience with issues like this and if so what moldflow results did you use. Not sure how to corelate shear stress results to surface issues. Isn't shear stress happening below the surface at the molten/frozen layer interface? Or would these issues arise from excessive shear through the gates which is just tearing up the material. We don't do a lot of painted parts so this is new to us.
Thanks for any input😁
Adam
