Running multiple simulations using VB script
Message 1 of 13
Hello Modelers,
I am trying to learn API. I wrote a visual basic script with creates multiple study files from a study file named 'sample.sdy' by changing injection time values. I also have command to start the analysis added in the script. I have written the script in the post for reference.
The problem is when i run the script, the multiple study files are created but all of them are simulated with same injection time, and not the injection time i set using the script. Mostly they take the injection time value of the last study file created (Refer the script : Injection time = 4s, from xyz.sdy is taken by all the studies (abc.sdy and lmn.sdy) here). Please help me with this thing because i have no idea what is going on here. Is this a bug or i am implementing incorrectly?
Arjav
<----------------------------Test.vbs------------------------------------>
'%RunPerInstance
'@ DESCRIPTION
'@ Macro recorded by Synergy on 24-Apr-2018 at 15:17:56
SetLocale("en-us")
Dim SynergyGetter, Synergy
On Error Resume Next
Set SynergyGetter = GetObject(CreateObject("WScript.Shell").ExpandEnvironmentStrings("%SAInstance%"))
On Error GoTo 0
If (Not IsEmpty(SynergyGetter)) Then
Set Synergy = SynergyGetter.GetSASynergy
Else
Set Synergy = CreateObject("synergy.Synergy")
Synergy.OpenProject "E:\Scripting_trials\Scripting_trials.mpi"
Synergy.SetUnits "English"
Set Project = Synergy.Project()
Project.OpenItemByName "sample", "Study"
Set StudyDoc = Synergy.StudyDoc()
StudyDoc.SaveAs "abc"
Set PropEd = Synergy.PropertyEditor()
Set Prop = PropEd.FindProperty(30011, 1)
Set DVec = Synergy.CreateDoubleArray()
DVec.AddDouble 2
Prop.FieldValues 10100, DVec
PropEd.CommitChanges "Process Conditions"
StudyDoc.AnalyzeNow True, True
WScript.Sleep 10000
StudyDoc.SaveAs "lmn"
DVec.AddDouble 3
WScript.Sleep 10000
StudyDoc.SaveAs "xyz"
DVec.AddDouble 4
Replies (12)
Message 2 of 13
bernor_mf
Hi @Anonymous,
you need to add a save of study to store data.
Something like this:
StudyDoc.Save
WScript.Sleep 3000
The Sleep is to give system some time to save study.
And after changing process condtions for new study:
StudyDoc.Save
WScript.Sleep 3000
Outprompt this when testing:
'StudyDoc.AnalyzeNow True, True
'WScript.Sleep 10000
To make testing pass faster.
Also, set WScript.Sleep for each, as system depending.
I did a test of above, and it worked to set injection time of each of 1,2,3,4 s
checked by Compare Studies.
Hope this helps.
Berndt
( If my comments are accepted, provide "Kudos" as appreciation. If your request is answered/resolved, please click the "Accept as Solution" button. Thanks.)
Message 3 of 13
Hi @bernor_mf
Thanks for the reply.
I tried the solution suggested by you of incorporating a SAVE command. See in the script below.
The problem still persists. Like i said i am also able to generate multiple sdy files with different values of injection as 2s, 3s and 4s. But when analysis are run on it using 'StudyDoc.AnalyzeNow True, True', all the study files run with injection time of 4s.
Can you tell me why this is happening?
You can generate a simple sdy file and then run my script here, over it to see the issue.
Can you let me what fill time are you getting in the result from analysis of different study files?
Arjav
<-------------------------------------Modified_test.vbs-------------------------------------------->
'%RunPerInstance
'@ DESCRIPTION
SetLocale("en-us")
On Error GoTo 0
Else
DVec.AddDouble 2
StudyDoc.Save
WScript.Sleep 5000
WScript.Sleep 10000
DVec.AddDouble 3
StudyDoc.Save
WScript.Sleep 5000
WScript.Sleep 10000
DVec.AddDouble 4
StudyDoc.Save
WScript.Sleep 5000
Message 4 of 13
bernor_mf
Hi Arjav,
thank you for the feedback.
I better understand your issue.
Weird behavior. Have no explanation of why this is happening.
It should accept the change of parameter in study and use in analysis.
Will see when I get a time slot to dive in to this.
Might need another way of doing this.
Berndt
Message 5 of 13
Hi @bernor_mf
Thank you for the response.
Please do let me know when you get time and have worked on this.
Arjav
Message 6 of 13
bernor_mf
Hi
first, I could replicate the issue.
Investigating this, it is related to settings in Options.
Enter Options and Results tab, and the Duplicated Studies area:
Duplicate study - include results linked from original study
is the default setting.
Hence in script and StudyDoc.SaveAs will use this,
and that is why all studies get the same result, no matter changes of parameter.
They are linked to first study.
Changing to
Duplicate study - do not include any results
resolves the issue
Changing the parameters of duplicating studies
As I could replicate your issue, doing above change, gave the expected results.
The set injection time was used as expected.
Now, there is an object that can deal with this:
DuplicateStudyByName3
From Synergy API reference:
Boolean DuplicateStudyByName3  ( String  aName,
  Boolean  aSave,
  long  aDuplicateOption
Duplicates a study by its name, whether to save study before duplicate, also includes the type of duplication.
Parameters:
 aName  name of the study to duplicate
 aSave  whether to save study before duplicate
 aDuplicateOption  the type of duplication to perform.
0 = complete copy of results files.
1 = no results files included.
2 = include result files linked to original study [Existing DEFAULT].
Returns:
True if successful; False otherwise
Note:
The application tries to prevent you from duplicating study names in the project; however if you have duplicated study or report names in your project, this function will duplicate the first item that matches the name. If the duplicate option specified is invalid the default option will be chosen.
Example
This example duplicates the unsaved study named "My Study", including results that are linked to the study being duplicated.
 Project.DuplicateStudyByName3 "My Study",FALSE,2
Better to use DuplicateStudyByName3, as in control compared to StudyDoc.SaveAs.
After duplication, you can use RenameItemByName to rename your study.
Get the details from Synergy API reference.
Method is up to you.
Hope this will resolve the issue for you.
Berndt
Message 7 of 13
Hello @bernor_mf
Thank you so much for first acknowledging the problem i was facing and secondly for providing the correct solution.
I tried the first method and it works very well. I will also try the second method.
Arjav
Message 8 of 13
Where can I find this Setting in MFI 2013 ?
Message 9 of 13
bernor_mf
Hi @Anonymous,
if you refer to "Changing the parameters of duplicating studies" option, it was introduced to Moldflow Insight 2017, I believe. Hence not available in Moldflow Insight 2016 and older releases.
Hope this helps.
Berndt
Message 10 of 13
Hello @bernor_mf,
Thank you for the fast and kind answer.
Yes I reffer to duplicating a study without results.
For my Bachelorthesis I'm trying to process multiple Studies and change the Process parameters, the University only provides MFI 2013.
I have written the skript attached at the end to do this. but also get in each study (and exported log file) the same results, not beeing calculated for each setting.
Is there a way to delte the copied result from the duplicateStudy ?
Best regards,
Manuel
startTime = Now
SetLocale(1031) 'Germany
Synergy.SetUnits "Metric"
c = 0
for counter = 0.1 To 0.5 Step 0.1
	counter = Round(counter,1)
	Project.DuplicateStudyByName2 "Start", False
	Project.OpenItemByName "Start (Kopie)", "Study"
	Set Prop = PropEd.FindProperty(30011, 1) 'TCS für Einspritzzeit
	DVec.AddDouble counter
	Project.RenameItemByName "Start (Kopie)", "Study", counter
	logloc = "C:\\Users\\seitz-1\\Desktop\\Moldflow Makros\\Log\\" + CStr(counter) + ".log"
	StudyDoc.ExportAnalysisLog logloc
	StudyDoc.Close
	c = c+1
	next
diff = FormatDateTime (startTime - Now, 3)
msg = + CStr(c) + " Studien durchgefuehrt in: " + diff
MsgBox msg, 0, "Studie Abgeschlossen"
Message 11 of 13
bernor_mf
Hello Manuel,
you need to use StudyDoc.DeleteResults(0) to break the connection to previous study.
Also save , and wait save to completed and analysis to complete.
Below code works. (Did some changes to run on my side, which you have to adjust on your side.)
Synergy uses SetLocale("en-us"), so I think it should be kept.
Hope this helps.
Berndt
'SetLocale(1031) 'Germany
SetLocale("en-us") '** locale for synergy
c = 0
	Project.OpenItemByName "Start (copy)", "Study"
StudyDoc.Save
WScript.Sleep 3000 '*** wait 3s for study to be saved
	'Set Project = Synergy.Project()
	Project.RenameItemByName "Start (copy)", "Study", counter
	'Set StudyDoc = Synergy.StudyDoc()
StudyDoc.AnalyzeNow2 False, True, False '** last False will prevent showing prompt on GUI
WScript.Sleep 10000	'*** wait 10s for analysis to complete (or check status in JobMgr)
	'logloc = "C:\\Users\\seitz-1\\Desktop\\Moldflow Makros\\Log\\" + CStr(counter) + ".log"
	logloc = "C:\\Temp\\" + CStr(counter) + ".log"
	StudyDoc.Close
	c = c+1
	next
Message 12 of 13
Thank you a lot @bernor_mf. It works now !! Thank you for your investment and time and very accurate, helpful and friendly relply and for even testing it.
Message 13 of 13
bernor_mf
Hi Manuel,
thank you for your kind words.
Happy to help.
Happy programming and simulation. Smiley Happy
Berndt
