Regarding the Injection Pressure Setting for Moldflow Filling Stage
fqlb
fqlb
Can Moldflow be set to control the filling of plastic products through multi-stage injection pressure control
It seems that Moldflow can only set a stable injection pressure when it reaches the maximum pressure of the injection molding machine,Is there any other way to achieve it? @raalteh @bernor_mf
bernor_mf
@fqlb
A workaround you could try is to do a Velocity/Pressure switch-over early, by for example injection time at short time 0.001.
Then use Pack/holding control for pressure vs time profile.
Note: This probably requires more calculation time.
And make sure to set the intermediate intervals.
Could this be a way forward for you?
Berndt
( If my comments are accepted, provide "Kudos" as appreciation. If your request is answered/resolved, please click the "Accept as Solution" button. Thanks.)
dalil.chenouf5FSTX
Hello
you can use the "dynamic feed" feature to set-up a pressure curve
fqlb
thank you ,but it can only be used for hot runners, not for cold runners,And it seems that this pressure can only be set on the gate
fqlb
At present, it seems that this is the only method available, but the filling speed is uncontrollable. We hope that this feature can be developed in future Moldflow versions
