Project time script
Project time script
CaeTecos2021
Project time script
CaeTecos2021
Hi all,
can anyone help me --> we are using some script, where we put inside location of project folder and script automatically calculate the sum of wall clock time of all projects. This work fine with all Moldflow versions, but with new version of Moldflow 2023 the script put wrong wall clock time of DD mesh. Is there anyone, who can solve that? 🙂
bernor_mf
@CaeTecos2021
which method to you use in script to get the time?
Saving the analysis log to text file, and reading it?
Or, using this method:
API example: Extract information from screen out file
Seems as it not picking the right data field, for some reason.
You need to check this.
Noticed there are ","  comma signs for decimal numbers, and Synergy uses "." dot as comma signs.
This could sometimes cause issues in scripts.
When running from Synergy, you normally add SetLocale("en-us") , to get this right.
Berndt
( If my comments are accepted, provide "Kudos" as appreciation. If your request is answered/resolved, please click the "Accept as Solution" button. Thanks.)
