There is a problem with 'reflect' option too. I hope the below example is self-explanatory.
Solved by Paul.Larter. Go to Solution.
Can you please make sure in 2017.3 that the reference point is the correct coordinate you wish to use. There is a known issue that if you select a node the reference point field is not updated. This issue is addressed in our next quarterly release.
The solution now in 2017.3 is to either make a query of the node or use the measure tool to get the coordinates, and then copy and paste these into the reference point field.
Regards
Paul
Thanks for your reply!
Yes it's happening, exactly what you said. We'll manage it making 'query' (or using 'measure' tool) until next release.
Biraj
we are seeing the same issue with rotating parts around an axis. Thanks for the tip.
Hello, Yes, this issue affects the move commands that use a reference point like Rotate, Scale and Reflect. This issue is fixed for our next quarterly release.
Regards
Paul
