Message 1 of 10
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello everyone,
I'm trying to output "Mesh type and global edge length" from an ".out" file using the "cmmessage".
I understand the MSCD formatting to some extent (through the API examples here) to be able to extract information from the log.
Because mesh information from the Mesh Log file, I can not use StudyDoc.GetResultPrefix go with ("Flow"),("Cool") or ("Warp") . I tried StudyDoc.GetResultPrefix("Mesh Log") but it did not work.
Any help to understand how to work with Mesh Log would be appreciated.
Thanks in advance.
My script below:
'%RunPerInstance
'@ DESCRIPTION
'@ This script shows how to extract information from the screen out (.out) file.
'@ Several examples are shown
'@ This script perfoms a similar function to the studyrlt command
'@ studyrlt <study> -message <sequence> <message ID> <occurrence> <item>
'@ Some knowledge of the format used in the .out file is required.
'@ please see details in the ..../data/dat/cmmesage.dat for details
'@ Some know of the analysis sequences is required.
'@ please see details in the ..../data/dat/process.dat for details
'@ SYNTAX
'@ RaadScreenOutput
'@ PARAMETERS
'@ none
'@ DEPENDENCIES/LIMITATIONS
'@ Assumes a Flow analysis has been run and the required study file is selected and open.
'@ Some knowledge of the MSCD format as defined in message.dat is required
'@ Limited error checking is performed
Option Explicit
SetLocale("en-us")
Dim Synergy
Dim SynergyGetter
On Error Resume Next
Set SynergyGetter = GetObject(CreateObject("WScript.Shell").ExpandEnvironmentStrings("%SAInstance%"))
On Error GoTo 0
If (Not IsEmpty(SynergyGetter)) Then
Set Synergy = SynergyGetter.GetSASynergy
Else
Set Synergy = CreateObject("amiws.Synergy")
End If
Dim StudyDoc
Set StudyDoc = Synergy.StudyDoc()
' Get the name of the .out file associated with the flow results.
' Note: This assumes a Flow analysis sequence was run.
Dim lName
lName = StudyDoc.GetResultPrefix("Flow")
Dim lOutName
lOutName = lName & ".out"
' Create and Populate the ScreenOutput Class for the lOutName
Dim lMessages
Set lMessages = New ScreenOutput
lMessages.LoadOutputFile(lOutName)
Dim MM, lStr
'MSCD 1902014 1 0 0 0 0 1 1
' Mesh type:
Set MM = lMessages.GetMessage(1902014,0)
lStr = " Mesh type = " & CStr(MM.GetString(0))
MsgBox CStr(lStr)
'MSCD 1902003 1 0 0 0 0 0 1
' Global edge length: %11.4G
' m,1,1
Set MM = lMessages.GetMessage(1902003,0)
lStr = "Global edge length = " & CStr(MM.GetFloat(0)*1000)
MsgBox CStr(lStr)
' ---- Message class
Class Message
Private mMSCD ' MSCD Message ID
Private mNumString ' Number of Strings associated with the Message
Private mNumFloat ' Number of Floats Associated with the Message
Private mStrings() ' The Strings Associated with the Message
Private mFloats() ' The Numerical Values Associated with the Message
Public Sub SetMSCD(aMSCD)
mMSCD = aMSCD
End Sub
Public Sub SetNumString(aNumString)
mNumString = aNumString
End Sub
Public Sub SetNumFloat(aNumFloat)
mNumFloat = aNumFloat
End Sub
Public Sub AddFloat(aFloat)
mNumFloat = mNumFloat + 1
ReDim Preserve mFloats(mNumFloat)
mFloats(mNumFloat-1) = aFloat
End Sub
Public Sub AddString(aString)
mNumString = mNumString + 1
ReDim Preserve mStrings(mNumString)
mStrings(mNumString-1) = aString
End Sub
Public Function GetMSCD()
GetMSCD = mMSCD
End Function
Public Function GetString(aIndex)
GetString = ""
If aIndex >= 0 And aIndex < mNumString Then
GetString = mStrings(aIndex)
End if
End Function
Public Function GetFloat(aIndex)
GetFloat = ""
If aIndex >= 0 And aIndex < mNumFloat Then
GetFloat = mFloats(aIndex)
End if
End Function
Public Function GetNumString()
GetNumString = mNumString
End Function
Public Function GetNumFloat()
GetNumFloat = mNumFloat
End Function
Private Sub Class_Initialize
mMSCD = -1
mNumString = 0
mNumFloat = 0
End Sub
End Class
Class ScreenOutput
Private mMessages() ' Array of Messages associate with the screen output File
Private mNumMessages ' Number of messages in the screen output file
Public Function LoadOutputFile(aFile)
Const ForReading = 1
Dim FS
Set FS = CreateObject("Scripting.FileSystemObject")
Dim File
Set File = FS.OpenTextFile(aFile, ForReading)
While Not File.AtEndOfStream
Dim ID
ID = -1
' Read the MSCD
Dim Line,lenLine
Line = File.ReadLine
lenLine = len(Line)
If Not File.AtEndOfStream or lenLine >= 1 Then
ID = Line
Dim curMessage
Set curMessage = New Message
curMessage.SetMSCD(ID)
' Read the number of strings
lenLine = len(Line)
Dim numString
numString = Line
' Read Strings
Dim i
For i = 1 To numString
lenLine = len(Line)
CurMessage.AddString(Line)
End if
Next
End if
' Read the number of floats
lenLine = len(Line)
Dim numFloat
numFloat = Line
' Read Floats
For i = 1 To numFloat
lenLine = len(Line)
CurMessage.AddFloat(Line)
End if
Next
End If
' Add current message to the list
AddMessage(CurMessage)
End If
Wend
File.Close
End Function
Public Sub AddMessage(aMessage)
mNumMessages = mNumMessages + 1
ReDim Preserve mMessages(mNumMessages)
Set mMessages(mNumMessages-1) = aMessage
End Sub
Public Function GetNumMessages()
GetNumMessages = mNumMessages
End Function
Public Function GetMessage(aMSCD,aOccur)
Set GetMessage = Nothing
Dim j
Dim lFindInstance
lFindInstance = aOccur
If aOccur < 0 Then
lFindInstance = 0
End if
Dim Count
Count = 0
For j = 0 To mNumMessages-1
'MsgBox mMessages(j).GetMSCD &"|"& aMSCD
If CStr(mMessages(j).GetMSCD) = CStr(aMSCD) Then
Count = Count + 1
If Count >= lFindInstance Then
Set GetMessage = mMessages(j)
Exit Function
End if
End if
Next
End Function
mNumMessages = 0
End Sub
End Class
