Moldflow Insight and HTV silicone rubber
Hi everyone !
Hope you are all well.
I would like to know if it is possible to work with HTV (High Temperature Vulcanized Silicon Rubber) with Moldflow Insight ?
Thanks for your answers.
Best Regards,
Pauline
bernor_mf
Hi Pauline,
as I understand the process the HTV material comes in blocks that are compressed.
Wacker reference : Solid silicone rubber (HTV) – High-Temperature Vulcanizing Silicone Rubbers
In such a case, I think reactive compression molding could be a way forward for you.
Have a look at the tutorial:
Compression Molding
Compression molding analysis results
Video:
Compression and Injection Compression Molding with Simulation Moldflow Insight
Hope this helps.
Berndt
( If my comments are accepted, provide "Kudos" as appreciation. If your request is answered/resolved, please click the "Accept as Solution" button. Thanks.)
Hi Berndt,
Thanks for your answer !
So if I understand well, I will be able to use HTV silicone rubber by using the compression molding analysis of Moldflow Insight ?
I will try that, thanks again !
Best regards,
Pauline
bernor_mf
Hi Pauline,
yes, I believe so, and you need Moldflow Insight Ultimate
See:
Compare products Moldflow Insight and Moldflow Adviser
Further, you need material data for thermoset/reactive of HTV.
Could not find such in official Moldflow material database for reactive materials.
Check with material supplier if they have an .udb-file for simulation or could suggest an equvivalent material.
Step through the tutorial for compression molding with the available model to download, and test a reactive material to get the hint of it.
Berndt
Hi Berndt,
Thanks a lot for your help ! I will follow your advice.
Best regards,
Pauline
