Hello.
I want to export a Moldflow result file (*.mfy). After marking the fill-result, exporting the mfy file leads to fatal crash without any warnings.
Trying different things (restart, reboot, mark other result, other project) leads to same error.
I'll be pleased if someone could give some helpfull hints.
Regards.
Try running the clean registry as stated in the below link
Did you tried to export only fill time result? i mean only one result, if you are succeeding please let me know
if the result file size is more than it may not get exported
check the access permission for the drive where you are saving the MFR file
