Moldflow 2026.0.1 is available
Dear Moldflow users,
I’m happy to let you know that Moldflow 2026.0.1 is available for download.
Before we get into what’s new
A few important things.
- This 2026.0.1 installs on top of Moldflow 2026 FCS. In other words it will not be installed next to the FCS release.
- Once the update is installed you may have to re-select the license the you use, using the Moldflow License configuration tool (mlc.exe) in your installation directory.
- We do not expect result changes, with one small exception; slight differences in results compared to previous versions for pressure triggered valve gates in 3D. This should hopefully.
Where to get it?
You can download the updates form two places:
- Manage.autodesk.com in the Product Updates section
- From your Autodesk Access tray app.
What’s New
The highlights of the release are:
- Support for Python based scripting.
- Additional result exports in Scalaris form for use in Digimat
- A new Scorch index result for thermoset processes
- Speed improvements for delete nodes
- Material database and CAD translator updates.
- SCM support for multiple proxy servers
- 55 pre-existing bugs and crashes fixed.
More details can be found in the attached .pdf and the online help.
Moldflow Scandium 2026.0.1
We also released a new Scandium Technology preview. The Scandium Technology preview is a free test version of Moldflow Insight that enables new capabilities in your commercial version of Moldflow Insight. This is available upon request through an application here. Existing Scandium participants get access to new Scandium Files and documentation by logging into https://feedback.autodesk.com/ and follow Project Scandium for Moldflow Insight. New applicants can apply here: https://feedback.autodesk.com/welcome/key/F43KDMRN2HP6CGND
New in 2026.0.1 Scandium features are:
- Enhanced valve gate control options for beam valve gates in 3D
- Part Insert expansion and compression during Filling and Packing
For more information, you can find the details in the Scandium documentation and in the Scandium specific slides in the attached What’s New in 2026.0.1 .pdf
Important!
If you had the Scandium Technology preview installed previously, to get access to the new capabilities you will need to:
- First install the 2026.0.1 Update
- Apply the new scandium files specific for 2026.0.1
Final note
On October 14 Autodesk will stop supporting Windows 10. We are following Microsoft in this (https://support.microsoft.com/en-us/windows/windows-10-support-ends-on-october-14-2025-2ca8b313-1946...)
Work on the next release is already in full swing.
Best regards,
Hanno van Raalte and the Moldflow team
Product Manager - Injection Molding & Moldflow products
