Hello everyone,
we are trying to perform injection molding simulation of a part which is of the order of 1 mm. the polymer is Ultem 1010. In Moldlow's database, the quality indicators for ultem 1010 (for fill, pack and warp) are bronze.
The warpage (seen during experiments) on the concerned surface of this part is around 1 um. Hence, i have some of questions:
1. can moldflow predict such small warpages?
2. As the quality indicators are bronze, for micro injection molding, do we need to go for material characterization?
3. what are the best practices for micro injection molding modeling?
Nikhil
1.simulating micro molding with Moldflow will not be an issue.and can predict warpage. Co-relating with actual is very difficult. as speed of fill, providing venting & measurement of warpage.
2. Best with gold quality for all the simulation.
3. Experienced person in micro-molding should comment on this & can give guideline
Refer this link for guidelines & some points to note
Similar question already came couple of times in forum
2. http://forums.autodesk.com/t5/moldflow-insight/micro-injection/m-p/4805547/highlight/true#M3668
just wanted to add a link to a paper which has some insight to this as well:
Hope this helps.
Berndt
Hi @Anonymous,
To add to the great references both @madhukeshwart and @bernor_mf provided, I've also listed the suggestions given through your support case below as a reference for others.
Cheers!
