mesh import problem
I want to use ANSYS 14.5 to mesh an assembly. The mesh is generated and exported without errors (mesh setting: tetras, no element middle knots).
To use the mesh in Moldflow Synergy 2014, I export it as NASTRAN format (.nas).
When I try to import the mesh into Moldflow, I can choose the .nas-file and start the import, but after a short while the import stops with an error message: "no entities imported from CAD-file".
The complexity of the part makes no difference. It even happens with a simple test geometry (cube etc.)
I tried every combination of input options, the problem persists. How can I it?
Moldflow import log:
Begin reading file
Opening internal database
Begin reading file
Attempting to open file
File open OK
End reading file
Import post process begin
Import post process end
Closing internal database
Import Summary----------------------------------------
nodes : 0
beams : 0
triangles: 0
tetras : 0
curves : 0
surfaces : 0
regions : 0
stl reps : 0
WARNING-----------------------------------------------
No Entities imported.
ERROR-------------------------------------------------
No entities imported from CAD file.
