Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Macro Running issue in multiple windows
4 REPLIES 4
adevadkar
242 Views, 4 Replies
Hello Guys,
I would like to run macro on different Moldflow windows,
Macro running option disable for other windows, only active in first window
When I try to run directly it run in the only first Moldflow window.
Any solution for that, I am using Moldflow insight 2023 Version.
4 REPLIES 4
bernor_mf
in reply to: adevadkar
@adevadkar
In Options, tab General, there is a "Macro/Scripts" settings.
I have that un-checked, and can run macros in different started UI's of Moldflow Synergy.
Berndt
( If my comments are accepted, provide "Kudos" as appreciation. If your request is answered/resolved, please click the "Accept as Solution" button. Thanks.)
adevadkar
in reply to: bernor_mf
@bernor_mf
I have tried that option also,
Not working.
bernor_mf
@adevadkar
Thank you for the update.
Sounds a bit strange.
Hard to nail.
The buttons could be greyed out if a macro has a dialog window open, connected to Synergy.
Or could be a ghost process of wscript.exe.
A last resort would be to do a cleanreg:
Running a Clean Registry in Moldflow Products
Berndt
c_liguori
Hi @adevadkar
Maybe you have an old  macro.
You should read first line in the macro, opening it with a text editor.
Verify if it starts with:
'%RunPerInstance
This should let the macro work also in other Synergy than the first opened.
Regards
Technology Administrators
