Improper Meshing
Improper Meshing
riad.ashraf
Improper Meshing
riad.ashraf
Dear Altrusits,
I have got a meshing problem. I have selected the thickness meshing and plate surface meshing differently. Meshing in the thickness section is ok but in the plate section the thickness is not homogenous. I am sending the screenshot. Can you please look at this? Let me know if you have any solution.
Best regards.
bernor_mf
Hi @riad.ashraf ,
the mesh result as shown in picture is expected, I would say.
If main surfaces has higher edge length , and edge surfaces (thickness direction) has lower edge length,
there will be an transition area of mesh from smaller to larger elements.
Berndt
( If my comments are accepted, provide "Kudos" as appreciation. If your request is answered/resolved, please click the "Accept as Solution" button. Thanks.)
