Image Capture
Image Capture
Message 1 of 10
Image Capture
Hi all,
Moldflow Image Capture Option quality poor compared with snip tool,
While capturing design areas like flange , ribs , boss we do zoom in more detail of respect areas, right that time image quality much poor,
Attached image file i have mentioned with red line inside mesh whitish colour,
Please provide your valuable suggestions,
Muthuraja
Replies (9)
Message 2 of 10
PascalGosset
I don’t agree with you.
I think the quality of the pictures created by Moldflow is good (I hope it’ll last.)
Look at the comparison I made.
It shows the same picture, enlarged 2 times, saved in Jpeg and Gif with Moldflow, Windows capture tool * and the software IrfanView. (*is it what you mean by “snip tool”?)
You can see the results got with Moldflow are not so bad.
Personally, I prefer the Gif format because it gives sharper colors and writings.
IrfanView works well enough.
Your picture is strange. I never saw that, edges missing.
I hope this reply will help you.
Signature: "Maybe Moldflow does not work properly, but the real world neither" my son...6 years old 😉
Message 3 of 10
Hi Petr,
Thanks for the reply,
I do agree for your above comparison images results for filling shades,
can you check and post fill contour for the midplane meshes?
Muthuraja
Message 4 of 10
PascalGosset
So, this is a comparison of the filling contours displayed for a Midplane model.
My conclusions remain the same:
  • Windows Capture works bad above all for GIF
  • The pictures quality of Moldflow and IrfanView is good
  • GIF images are sharper than JPG.
I made several tests to try to reproduce the defect you have.
I did not succeed.
But, now I think I had this problem a long time ago.
Which version of Moldflow do you use?
 Is your graphics card driver updated?
Message 5 of 10
Hi petr,
Thanks for the work u have done,
Now i can try to capture images from moldflow itself for report preparation,
we r using MF-2017.3- Graphicscard- NVIDIA Quadro P2000
Muthuraja
Message 6 of 10
bernor_mf
if using Nvidia graphics card, it many times improve performance by changing
Global Presets to “3D App – Visual Simulation”
First, update graphics driver.
Those topics are for different reason, but shows how to do this setting,
Global Presets to “3D App – Visual Simulation”:
Moldflow scale or legend bar missing when displaying results
Moldflow: Bounding box not visible when using select tools
It could also be so, that you maybe need to change opacity.
In the Plot properties, tab Mesh Display, Surface display, below Transparent, you can change Opacity.
Would try updating graphics driver, and set Global Presets to “3D App – Visual Simulation” first.
Hope this helps.
Berndt
( If my comments are accepted, provide "Kudos" as appreciation. If your request is answered/resolved, please click the "Accept as Solution" button. Thanks.)
Message 7 of 10
Ashwatthaman
Hello team,
@bernor_mf  & @juan.zamora.ruiz
After examining the specific results and capturing the image in the macro, what steps should I take next?
Message 8 of 10
juan.zamora.ruiz
Autodesk Support
Autodesk Support
Hi @Ashwatthaman ,
Could you elaborate your query? I'm afraid I don't have a clear understanding on the context of your question.
I recommend you raise a new thread though, so we have a self-contained thread for your query and keep this thread for the original topic.
Juan
Juan Zamora
Technical Support Specialist
Message 9 of 10
bernor_mf
@Ashwatthaman
I do not follow what you are looking for.
Agree with @juan.zamora.ruiz : Please elaborate , and open a new thread.
Thank you.
Berndt
Message 10 of 10
PascalGosset
Hello simulators,
I'm surprise to see this post again...  🙂
In 2019, I wrote "I think the quality of the pictures created by Moldflow is good (I hope it’ll last.)"
Maybe you won't agree with me but...
now I think... unfortunately... it didn't last...  😞
The current compression algorithm degrades the pictures quality more than before.
And also, the grey used now to display the part is darker.
Look at this comparison between Moldflow and IrfanView:
