How to screen out the Short shot warning from log
mantd
mantd
Hello.
I'm trying to screen out "** WARNING 220131 ** Short shot detected." by using the "cmmessage".
I understand the MSCD formatting to some extent (through the API examples
) to be able to extract information from the log.
I had trouble with this script:
'MSCD 220131 2 0 0 0 0 0 11
' ** WARNING 220131 ** Short shot detected.
Set MM = lMessages.GetMessage(220131,0)
lStr = CStr(MM.GetString(0))
MsgBox CStr(lStr)
Short shot warning in "Flow" log but did not screen out.
Please help
Thank in advance
'%RunPerInstance
'@ DESCRIPTION
'@ This script shows how to extract information from the screen out (.out) file.
'@ Several examples are shown
'@ This script perfoms a similar function to the studyrlt command
'@ studyrlt  <study> -message <sequence>  <message ID> <occurrence> <item>
'@ Some knowledge of the  format used in the .out file is required.
'@ please see details in the ..../data/dat/cmmesage.dat  for details
'@ Some know of the analysis sequences is required.
'@ please see details in the ..../data/dat/process.dat  for details
'@ SYNTAX
'@ RaadScreenOutput
'@ PARAMETERS
'@ none
'@ DEPENDENCIES/LIMITATIONS
'@ Assumes a Flow analysis has been run and the required study file is selected and open.
'@ Some knowledge of the MSCD format as defined in message.dat  is required
'@ Limited error checking is performed
Option Explicit
SetLocale("en-us")
Dim Synergy
Dim SynergyGetter
On Error Resume Next
Set SynergyGetter = GetObject(CreateObject("WScript.Shell").ExpandEnvironmentStrings("%SAInstance%"))
On Error GoTo 0
If (Not IsEmpty(SynergyGetter)) Then
  Set Synergy = SynergyGetter.GetSASynergy
Else
  Set Synergy = CreateObject("amiws.Synergy")
Dim StudyDoc
Set StudyDoc = Synergy.StudyDoc()
' Get the name of the .out file associated with the flow results.
' Note:  This assumes a Flow analysis sequence was run.
Dim lName
lName = StudyDoc.GetResultPrefix("Flow")
Dim lOutName
lOutName = lName & ".out"
' Create and Populate the ScreenOutput Class for the lOutName
Dim lMessages
Set lMessages = New ScreenOutput
lMessages.LoadOutputFile(lOutName)
Dim MM, lStr
MsgBox CStr(lStr)
' ---- Message class
Class Message
  Private mMSCD   ' MSCD Message ID
  Private mNumString    ' Number of Strings associated with the Message
  Private mNumFloat     ' Number of Floats  Associated with the Message
  Private mStrings()    ' The Strings Associated with the Message
  Private mFloats()  ' The Numerical Values Associated with the Message
  Public Sub SetMSCD(aMSCD)
    mMSCD = aMSCD
  End Sub
  Public Sub SetNumString(aNumString)
    mNumString = aNumString
  End Sub
  Public Sub SetNumFloat(aNumFloat)
    mNumFloat = aNumFloat
  End Sub
  Public Sub AddFloat(aFloat)
    mNumFloat = mNumFloat + 1
    ReDim Preserve mFloats(mNumFloat)
    mFloats(mNumFloat-1) = aFloat
  End Sub
  Public Sub AddString(aString)
    mNumString = mNumString + 1
    ReDim Preserve mStrings(mNumString)
    mStrings(mNumString-1) = aString
  End Sub
  Public Function GetMSCD()
    GetMSCD = mMSCD
  End Function
  Public Function GetString(aIndex)
    GetString = ""
    If aIndex >= 0 And aIndex < mNumString Then
       GetString = mStrings(aIndex)
    End if
  End Function
  Public Function GetFloat(aIndex)
    GetFloat = ""
    If aIndex >= 0 And aIndex < mNumFloat Then
       GetFloat = mFloats(aIndex)
    End if
  End Function
  Public Function GetNumString()
    GetNumString = mNumString
  End Function
  Public Function GetNumFloat()
    GetNumFloat = mNumFloat
  End Function
  Private Sub Class_Initialize
    mMSCD = -1
    mNumString = 0
    mNumFloat = 0
  End Sub
End Class
Class ScreenOutput
 Private mMessages()  ' Array of Messages associate with the screen output File
 Private mNumMessages  ' Number of messages in the screen output file
  Public Function LoadOutputFile(aFile)
    Const ForReading = 1
    Dim FS
    Set FS = CreateObject("Scripting.FileSystemObject")
    Dim File
    Set File = FS.OpenTextFile(aFile, ForReading)
        While Not File.AtEndOfStream
      Dim ID
      ID = -1
        ' Read the MSCD
        Dim Line,lenLine
    Line = File.ReadLine
    lenLine = len(Line)
    If Not File.AtEndOfStream or lenLine >= 1 Then
      ID = Line
      Dim curMessage
      Set curMessage = New Message
      curMessage.SetMSCD(ID)
      ' Read the number of strings
      lenLine = len(Line)
        Dim numString
        numString = Line
        ' Read Strings
        Dim i
        For i = 1 To numString
          lenLine = len(Line)
            CurMessage.AddString(Line)
          End if
        Next
      End if
      ' Read the number of floats
      lenLine = len(Line)
        Dim numFloat
        numFloat = Line
        ' Read Floats
        For i = 1 To numFloat
          lenLine = len(Line)
           CurMessage.AddFloat(Line)
          End if
        Next
      ' Add current message to the list
      AddMessage(CurMessage)
  Wend
    File.Close
  End Function
  Public Sub AddMessage(aMessage)
  mNumMessages = mNumMessages + 1
    ReDim Preserve mMessages(mNumMessages)
    Set mMessages(mNumMessages-1) = aMessage
  End Sub
  Public Function GetNumMessages()
    GetNumMessages = mNumMessages
  End Function
  Public Function GetMessage(aMSCD,aOccur)
    Set GetMessage = Nothing
    Dim j
    Dim lFindInstance
    lFindInstance = aOccur
    If aOccur < 0 Then
      lFindInstance = 0
    End if
    Dim Count
    Count = 0
    For j = 0 To mNumMessages-1
      'MsgBox mMessages(j).GetMSCD &"|"& aMSCD
      If CStr(mMessages(j).GetMSCD) = CStr(aMSCD) Then
         Count = Count + 1
         If Count >= lFindInstance Then
           Set GetMessage = mMessages(j)
           Exit Function
         End if
      End if
    Next
  End Function
  mNumMessages = 0
  End Sub
End Class
bernor_mf
@mantd
I tried to get it to run, but unfortunately I found no solution.
Not sure why and where it goes wrong.
Tried different combinations and also short from Midplane:
" ** WARNING 128271 ** Short shot detected. The flow front froze before
the part could be filled. "
Did you resolve it?
Might be a limitation.
Let's see if someone else in community has any idea or solution to this.
Berndt
( If my comments are accepted, provide "Kudos" as appreciation. If your request is answered/resolved, please click the "Accept as Solution" button. Thanks.)
RK1097
Disclaimer: I have a very rudimentary understanding of MSCD and Synergy API in general. Absolutely no programming skills, so take everything you see below with a big grain of salt.
After spending a bit of time, I was able to determine whether a short shot exists in a midplane mesh, haven't yet tried a DD or 3D. Each mesh type has a different MSCD for short shot and each short shot "cause" has a different MSCD.
These are the ones I believe to be strictly related to Mid-plane mesh:
Based on this info, you would need to run through each MSCD depending on mesh type and see what values it returns.
Here's a very crude code that I was able to come up with (Strictly for Mid-Plane results):
If lOutName = "" then
Msgbox "Unable to fetch .Out file"
Wscript.quit
Else
Dim lMessages
Dim MM, lFloat0, lFloat1
Set MM = lMessages.GetMessage(128270,0)
'MSCD 128271 for mid-plane, short shot due to machine injection pressure or packing pressure is insufficient.
lFloat0 = CStr(MM.GetFloat(0))
Set MM = lMessages.GetMessage(128271,0)
'MSCD 128271 for mid-plane, short shot due to part frozen before it could fill.
lFloat1 = CStr(MM.GetFloat(1))
'If either of the MSCD return the value 0 then declare short shot
If ((lFloat0 OR lFloat1) <> 0) then
Msgbox "Short Shot"
else
Msgbox "No Short shot"
Wscript.quit
'MSCD 128270 3 0 0 0 0 0 11
'    ** WARNING 128270 ** Short shot detected. The machine injection pressure or packing
'                         pressure is insufficient.
'MSCD 128271 3 0 0 0 0 0 11
'    ** WARNING 128271 ** Short shot detected.  The flow front froze before
'                         the part could be filled.
'MSCD 128272 3 0 0 0 0 0 11
'    ** WARNING 128272 ** Short shot detected.  The clamp force of the
'                         injection molding machine is insufficient.
'MSCD 128273 3 0 0 0 0 0 11
'    ** WARNING 128273 ** Short shot detected.  The stroke volume of the
If there is no "128270" or "128271" line in the .out file that simply meant no short shot (due to "The Flow front froze..."). If there was another reason for short shot, I'd have gotten false output showing "No Short shot" whilst short shot existing in actuality. That's where you'd need to scan for other MSCDs "128272/73" for it to work perfectly (can add them easily in existing code above, if needed).
I had issue with .out file not being detected and that caused false reading in screen output, that's why the code starts with ensuring whether the script is able to read it, if you want to remove the check, you're welcome to delete it.
Just FYI, I think the reason you're not getting any output from your code is that there are no "String" values in the ".out" file that are associated to "Short shot". Although, I could be completely wrong about this.
Here's what my .out file had:
"128271
0
1
0"
So, only numbers (i.e. float values).
I hope this helps you, should be very easy to inject DD and 3D MSCD to make it a universal check tool.
mantd
hi,
thank for your attention @bernor_mf  @RK1097
I resolved this case by "unofficial way". 😆
I exported the analysis log file, read this file and find the keyword "220131", if it found => short shot detected.
Have a good day!
'%RunPerInstance
'@ DESCRIPTION
'@ SYNTAX
'@ RaadScreenOutput
'@ PARAMETERS
'@ none
Option Explicit
SetLocale("en-us")
Dim Synergy
Dim SynergyGetter
On Error GoTo 0
Else
'Export Analysis Log
StudyDoc.ExportAnalysisLog "......._analysis.log"
Set file = fso.OpenTextFile("......._analysis.log", ForReading)
content = file.ReadAll
substrToFind = "220131"
If InStr(content, substrToFind) <= 0 Then
    WScript.Echo "No short shot"
Else
    WScript.Echo "Short shot detected."
bernor_mf
@mantd
happy to hear you resolved the issue. 😊
And thank you for sharing your creative solution with the community.
Very much appreciated.
Berndt
bernor_mf
@RK1097
right, agree on your comment and thank you for spending time to look in to it in detail.
Much appricated, and helpful for the community.
As there is no string value associated to MSCD code in .out, it makes it more complex.
Short shot message has different messages ID, depending on mesh type, process, and reason for short shot.
I would be nice that the ..../data/dat/cmmesage.dat could be read and and MSCD and string associated.
Increases the complexity quite a bit.
Believe the workaround provided by @mantd  is the way to go for now.
Thanks.
Berndt
