How to enter process parameters in batches for automatic analysis
1292909313
1292909313
There are 37 different process settings in the picture below, how do I get the software to automatically set these process parameters and analyze them? Instead of manually changing the process parameters every time the scheme is re-replicated.
bernor_mf
@1292909313
this is possible with Synergy API.
I suggest you record your workflow in a macro.
This will give the basic code needed.
Such as: Open study , set parameters, save to new name and close.
Suggest to put parameters in file, that could be read.
So some programming needed to accomplish this automation.
Unfortunately, I do not have an off the shelf solution for this, but hope this gives some ideas.
Berndt
( If my comments are accepted, provide "Kudos" as appreciation. If your request is answered/resolved, please click the "Accept as Solution" button. Thanks.)
h-fujitaDXJU5
Hi.
I have another method. Almost all steps are same as bernor_mf's solution.
Using "studymod" command with Windows batch file(.bat).
Moldflow Insight Help | The studymod utility | Autodesk
Base study file + modifier XMLfiles -> specific molding condition study files
37 XML files and a 37 line .bat file are needed.
(1)First, you specify TCODE from tcode.dat file in Moldflow folder or Macro recording
(2)Make modifier XML file each molding condition by some what your favorite macro. I will write down below.
Moldflow Insight Help | Example 1 - Editing process settings | Autodesk
(3)"studymod base.sdy mod01.xml" 37times in .bat file
(4)run .bat file in Synergy command shell
Regards.
-----Excel VBA Example to generate modifier XML file from Excel table format
Sub GenerateXML()
Dim header(20) As String, footer(5) As String
Let header(1) = "<?xml version=""1.0"" encoding=""utf-8""?>"
Let header(2) = "<StudyMod title=""Autodesk StudyMod"" ver=""1.00"">"
Let header(3) = " <UnitSystem>Metric</UnitSystem>"
Let header(4) = " <Material ID=" & """" & Sheets(1).Range("Q3") & """" & "/>"
Let header(5) = " <Property>"
Let header(6) = " <TSet>"
Let header(7) = " <!--Process controller-->"
Let header(8) = " <ID>30011</ID>"
Let header(9) = " <SubID>1</SubID>"
Let footer(1) = " </TSet>"
Let footer(2) = " </Property>"
Let footer(3) = "</StudyMod>"
Open ThisWorkbook.Path & "\" & Sheets(1).Range("E3") & ".bat" For Append As #2 'Windows batch file
For i = 1 To 10
    Open ThisWorkbook.Path & "\" & Sheets(1).Range("W" & i + 6) For Append As #1 'Modifier XML file
    For j = 1 To 9
        Print #1, header(j)
    Next j
    'Write each molding condition to XML
    For j = 14 To 17
        Print #1, "<!--" & Sheets(1).Cells(5, j) & "-->"
        Print #1, " <TCode>"
        Print #1, " <ID>" & Sheets(1).Cells(6, j) & "</ID>"
        Print #1, " <Value>" & Sheets(1).Cells(i + 6, j) & "</Value>"
        Print #1, " </TCode>"
    Next j
    '(now j=18)
    Print #1, " <Value>" & Sheets(1).Cells(i + 6, j + 1) & "</Value>"
    Print #1, " <Value>" & Sheets(1).Cells(i + 6, j + 2) & "</Value>"
    'Write last 3 lines
    For j = 1 To 3
        Print #1, footer(j)
    Next j
    Close #1
    ' Append a Windows command line to the .bat file
    Print #2, "studymod " & Sheets(1).Range("U" & i + 6) & " " & Sheets(1).Range("V" & i + 6) & " " & Sheets(1).Range("W" & i + 6)
Next i
Close #2
End Sub
Thanks a lot, I've solved this with python
