Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
How to calculate 6 tests at the same time with 2 licenses
8 REPLIES 8
Message 1 of 9
691 Views, 8 Replies
Dear
We have problem with license Moldflow Insight Premium, please help us soon because we need software to work.
Last time we buy 1 license Moldflow Insight Premium and we can calculate 3 tests at the same time.
Now we buy add 1 more license and still calculate 3 tests at the same time.
Question is: how many tests we can use with 2 license Moldflow Insight Premium?
If we use 1 license can use  3 tests at the same time
If we use 2 licenses can use  6 tests at the same time, right?
How to solve this issue?
I'm looking forward to hearing from you soon,
Thanks alot,
8 REPLIES 8
Message 2 of 9
nordhb
a newer license will supersede an older license for the same product and version,
unless they were issued with the same date stamp.
Did you issue licenses the same date?
Otherwise, cut a license for each serial number of Insight the same date,
and combine the new licenses in to major license file.
This should resolve the issue, and get access to 2x 3 instances (=6) for the solver.
Hope this helps.
Berndt
Berndt Nordh
Message 3 of 9
in reply to: nordhb
Dear Berndt,
Thanks for your answer,
Last 2 years we buy 1 license Moldflow Insight Premium 2014
This year we buy add 1 more license 2016 and down grate to 2014
So, what can we do now?
Best regards,
Phạm Thị Mỵ
ĐTDĐ: 0985 925 345
Message 4 of 9
nordhb
Hi Phạm Thị Mỵ,
so if I understand you correctly:
1) You have 1 serial number for Moldflow Insight Premium 2014, right?
2) You have 1 serial number for Moldflow Insight Premium 2016, but this has been
downgraded to a serial number for Moldflow Insight Premium 2014, right?
So if you now have 2 serial numbers of Moldflow Insight Premium 2014, you need to activate each license for both the same
date at http://registeronce.autodesk.com/
( http://knowledge.autodesk.com/customer-service/installation-activation-licensing/activate-register/o... )
Then combine (add) the 2 license files to your main license file. Remove the old for Moldflow Insight Premium 2014.
If you have 1 serial number for Moldflow Insight Premium 2014,  and 1 serial number for Moldflow Insight Premium 2016,
you can only run the solver of each release. Meaning Moldflow Synergy 2014 submit jobs to Insight 2014 and Moldflow Synergy 2016 submit jobs to Insight 2016.
Moldflow Synergy 2016 cannot submit jobs to Moldflow Insight Premium 2014 solver.
Moldflow Synergy 2014 cannot submit jobs to Moldflow Insight Premium 2016 solver.
Hope this helps.
Berndt
Berndt Nordh
Message 5 of 9
in reply to: nordhb
Dear,
Moldflow 2016 I buy Subscription and downgraded to 2014
But Moldflow 2014 I didn't buy Subscription
So I can do follow your guide or not?
http://knowledge.autodesk.com/customer-service/installation-activation-licensing/activate-register/o...)
I'm looking forward to hearing from you,
Message 6 of 9
in reply to: nordhb
Please help me to answer, very urgent with me
Message 7 of 9
Dear Berndt,
I follow your guide:
(you need to activate each license for both the same
Then combine (add) the 2 license files to your main license file. Remove the old for Moldflow Insight Premium 2014.)
Main license put in server, and 2 computers can run Moldflow. But Total 2 computers only can run 3 tests at the same time,
For ex: 1 computer run 2 tests, so another computer only can run 1 test.
How to do now Mr. Berndt ?
Thanks alot
Message 8 of 9
nordhb
Hi Phạm Thị Mỵ,
as I understand you created 2 new license files the same date: 1 for new Insight 2014 (downgraded 2016) and 1 for old Insight 2014 (not on subscription).
If you have both, then combined in to main license file. (removing the old ones, which had other date), right?
To Create a Combined License File
Then, did you restart the license server?
To Stop and Restart a Windows License Server
Then on license server, check :
Autodesk > Network License Manager > LMTools > LMTools Utility
tab Server Status : Perform Status Enquiry
Check you have the licenses there.
If steps are done as described, you should be able to run 2x 3 = 6 instances of Insight 2014.
Hope this helps.
Berndt
Berndt Nordh
Message 9 of 9
in reply to: nordhb
Dear Berndt,
Thanks for your greate support
Now we checking again
