Hot Runner
Hot Runner
2021898104
Hot Runner
2021898104
Hi, May I know how to run the analysis after I set the hot runner due to it told that my analysis was failed?
** ERROR 220120 ** No connection between beam and tetrahedral cavity elements.
Or else, how the process of mesh, set the runner, inject location flow?
bernor_mf
@2021898104
You need to fix the connectivity issue.
Use connectivity diagnostic to identify where the problem is located.
Click Mesh > Mesh Diagnostic > Connectivity
Good information:
"ERROR 220120: No connection between beam and tetrahedral cavity elements" in Moldflow
Solver message 220120
Hope this helps.
Berndt
( If my comments are accepted, provide "Kudos" as appreciation. If your request is answered/resolved, please click the "Accept as Solution" button. Thanks.)
vasyabc
Please check connectivity diagnostic if hot runner beams and part tetras are connected. if not connected need to merge nodes.
share image of hot runner and part tetra connectivity diagnostic result image.
B.Vasanth
