I'm trying to obtain a script that can generate a txt file that contains node xyz position and the node pressure in a certain time step.
I already have a VBScript that can generate a node XYZ positions file but i need to add the column that contains node pressure in a certain time step. Can anyone help me or give me a hint about how to add the code to generate that info?
This is the code in the file that i have
'%RunPerInstance
'@ DESCRIPTION
'@ Extract all Nodal Coordinates to a comma separated text file
'@ SYNTAX
'@ WriteNodalData
'@ PARAMETERS
'@ none
'@ DEPENDENCIES/LIMITATIONS
'@ History
'@ Created DRA 9/8/2006
Option Explicit
SetLocale("en-us")
Dim SynergyGetter, Synergy
On Error Resume Next
Set SynergyGetter = GetObject(CreateObject("WScript.Shell").ExpandEnvironmentStrings("%SAInstance%"))
On Error GoTo 0
If (Not IsEmpty(SynergyGetter)) Then
Set Synergy = SynergyGetter.GetSASynergy
Else
Set Synergy = CreateObject("synergy.Synergy")
Synergy.SetUnits "METRIC"
Dim StudyDoc, App
Dim FS, TemporaryFolder, TempFolder, Name, lFile
Dim Str, Node, NodeNumber, Coord
Set StudyDoc = Synergy.StudyDoc()
'Open a File in the users temporary Directory
Set FS = CreateObject("Scripting.FileSystemObject")
TemporaryFolder = 2
Set TempFolder = FS.GetSpecialFolder(TemporaryFolder)
Name = "data.txt"
Set lFile = TempFolder.CreateTextFile(Name, True)
' Write File Header
Str = "Node" & "," & "X" & "," & "Y" & "," & "Z" & vbCrLf
lFile.Write Str
' Loop through all nodal
Set Node = StudyDoc.GetFirstNode()
While Not Node Is Nothing
NodeNumber = StudyDoc.GetEntityID(Node)
Set Coord = StudyDoc.GetNodeCoord(Node)
Str = NodeNumber & "," & Coord.X & "," & Coord.Y & "," & Coord.Z & vbCRLF
lFile.Write Str
Set Node = StudyDoc.GetNextNode(Node)
Wend
' Close File
lFile.Close
' Notify user where the file is located
MsgBox "Nodal Data Recorded In File" & vbCRLF & TempFolder.Path & "\" & Name
' Open the File in Notepad
Set App = WScript.CreateObject("WScript.Shell")
Dim Command
Command = "notepad.exe " & TempFolder.Path & "\" & Name
App.Run Command
MsgBox "Script Complete"
Wscript.Quit
Thank you
-Gerardo
Solved by Javier.Jubierre. Go to Solution.
HI @gochoats01,
Thanks for sharing your macro and posting your question.
There are different ways to achive what you are looking for. The easiest way would be, now that you have the node ID and coordiantes, to export the pressure and to match both results. For doing that, you can export to a Patran file the results of the pressure (Results > Export and Publish > Patran). Moldflow will create a .nod file for each time-step, so you only need to merge the time step you need and the node-coordinate file.
Another way would be to use an API command. Here there are two options:
I hope it helps!
Cheers,
Javier
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Hi @gochoats01,
Thanks for posting in our Insight forum!
Did my answer to your post solved your problem? If yes, please accept my reply as solution. If not, let me know and we could go deeper in this topic.
Cheers,
Javier
Hello Javier,
Sorry about my late response, what you described above was ver useful to get this done.
Thank you!
-Gerardo
Hello everyone,
I'm with same problem. I tried GetScalarData obtied pressure for node, but can't.
@Javier.Jubierre you can help me?
