Announcements
Flow Rate
vgvimalkanth
Flow Rate
vgvimalkanth
What should be the flow rate considered for the Thermoplastic Injection Molding? Is there any minimum-maximum limit for it?
mppkumar
Hi @vgvimalkanth
flow rate depends on Injection molding machine used / screw diameter / screw speed
need to refer information manual of injection molding machine for max or min flow rate it can handle
M P Pradeep Kumar
If my views / comments acceptable, provide "Kudos" as appreciation, if answers your query, please click the "Accept as Solution"
vgvimalkanth
Thank you!
