Hello Every one,
When I increase frame number like 24 to 48 flow simulation works end to start direction. I only changed frame number so I couldn't find to fix it.
After reserve direction simulation error it shows always end to start direction flow like attached figure. How I can fix this and why this happened.
Hello
Go to the fill animation plot properties then go to the animation tab & change animation results from show higher values to show lower values.
Changing to show lower values will help to start fill animation from 0.0 sec (blue color)
Refer below image
Hope it will solve your problem.
Dhiraj
