Exporting warpped model and windage
n.soheylnokhaie
n.soheylnokhaie
Hello
About exporting the warpped model, we have 2 States in moldflow that each of them dividing to 4 Items:
  • Importing the CAD model directly to moldflow without and expanding scale (Shrinkage compensation scale)
a-actual, shrinkage compensation off
b- opposite, shrinkage compensation off
c- actual, shrinkage compensation on
d- b- opposite, shrinkage compensation on
2-importing the CAD model to moldflow that is scaled previously (Shrinkage compensation scale)with CAD software or in moldflow before running analysis and after analysis in warpage results :
e-actual, shrinkage compensation off
f- opposite, shrinkage compensation off
g- actual, shrinkage compensation on
h- opposite, shrinkage compensation on
My questions are :
1-for comparing the CAD model and output of the mold (molded part) (Cad model and warpped shape),
     should I use 1-C  ? and with scale  factor should be 1 ?
2-For windage, what’s the procedure for doing that?
     And which of above items should be used for morphing CAD model?  and what about the scale
    factor?
     The Video : “ASK THE MOLDFLOW EXPERTS - Windage From a Tooling Perspective”
       https://www.youtube.com/watch?v=zTaVzn_Yt9M
       in minute : 04’:28” , Step 6 :perform windage check
       Where can I do that ? could it be done in moldflow or CAD software? and how?
3-could you explain more about other items?
 Best Regards
mason.myers
Hello @n.soheylnokhaie ,
Tim VanAst from Autodesk presented on this topic during the 2023 Moldflow Summit.  You can sign up to watch the recording here:
https://www.autodesk.com/campaigns/advmfg-summit/overview
Your selection depends on the CAD used as an input to Moldflow (Tool CAD or Part CAD) and what you want to do with the warpage export.
Mason
