Error while exporting data to LS-DYNA
Hi all!
I have been trying to export fiber orientation from a Moldflow simulation to LS-DYNA using the command "mpi2dyn", but every time I do so an error message occurs. I have attached the error window below.
The simulation was made using fiber material, also filling, pack and warp was calculated successfully. The error also occurs while trying to export to another format, like abaqus!
I would be glad if someone could help me with this problem.
Tom
nordhb
can you check if you have privileges to run windows command line :
Start > Run
cmd <enter>
To run mpi2dyn above needs to work.
If it returns error, your IT admin need to give you privileges to run windows command line.
Let me know of the progress.
Berndt
Berndt Nordh
Thank you for the fast answer!
After getting the rights to run windows command line the export is now working fine!
Tom
