Moldflow Insight Forum
Welcome to Autodesk’s Moldflow Insight Forums. Share your knowledge, ask questions, and explore popular Moldflow Insight topics.
Cooling analysis in Moldflow Insight for multiple cycles
3 REPLIES 3
s155259
502 Views, 3 Replies
I am doing a project in my university with Moldflow Insight and we want to investigate the temperature distribution of the mold after multiple cycles.
Is it possible to do that?
Thank you
3 REPLIES 3
mppkumar
in reply to: s155259
Hi @s155259
Yes.. it's possible by simulating Cool (FEM) analysis
Please go thru the below link
https://knowledge.autodesk.com/support/moldflow-insight/learn-explore/caas/CloudHelp/cloudhelp/2014/...
M P Pradeep Kumar
If my views / comments acceptable, provide "Kudos" as appreciation, if answers your query, please click the "Accept as Solution"
mppkumar
Hi @s155259
Adding to that... Cool (FEM) is possible with 3D and Dual domain mesh type
you need to set the Mold temperature options as "Transient from production start-up"
"This will show how the mold heats up over time with consecutive injections until it reaches a steady-state. Once this steady-state has been reached, the mold temperature cycles reflect the transient within cycle changes"
Links which may be useful:
http://help.autodesk.com/view/MFIA/2017/ENU/?guid=GUID-4DB0EDB1-8DB3-4EDE-B385-64AA09EA6192
http://help.autodesk.com/view/MFIA/2017/ENU/?guid=GUID-4BE6E0D8-AC89-4389-94F2-967FDCA73104
http://help.autodesk.com/view/MFIA/2017/ENU/?guid=GUID-077521D7-6F22-4445-8EA7-E010A182E094
modeling procedure for Cool (FEM) process is slightly different from Cool (BEM) method
Follow the steps in the below link
http://help.autodesk.com/view/MFIA/2014/ENU/?guid=GUID-01F14CC6-6D6C-4503-A6E9-4443A2D6EC9B
Hope this helps in getting done your project... if you have any queries please write to us
For modeling Cool (FEM)
M P Pradeep Kumar
gochoats01
I think this can be done.
You have to define the following
  1. Cool(FEM)+Fill analysis sequence at least, you can define Cool(FEM)+Fill+Pack+Warp.
  2. Then go to Process Settings in the Cool(FEM) settings section
  3. Click Advanced Options
  4. Click "Edit" in Solver Parameters Option.
  5. Go to the Cool(FEM) Analysis tab
  6. In Mold Temperatura options change to Transient from production start-up
  7. Click in Cool(FEM) Solver Parameters button.
  8. Then change the Maximum number of transient mold temperature cycles to change the number of cycles you want to analyze.
Remember that if you want to perform a Cool(FEM) Analysis you have to create the Mold 3D mesh.
I hope this helps
Regards
-Gerardo
