Constraints BC in Moldflow
mahesh_a_patil
mahesh_a_patil
I am trying to constraints movements for few nodes in the Y and Z direction and give free movements only in the X-direction. (Refer image). I tried with the General Constraints option, but warp analysis is failing. (Refer to attached images). Let me know if anyone tried such an option.
Mahesh P
madhukeshwart
hi @mahesh_a_patil
  • What ever the constraint provided must be enough to prevent rigid body motion.
  • Provide appropriate constraints & wrong constraints may lead to failure of analysis
  • run only warpage, instead of Stress & warp analysis, may be your license may be supporting
  •  when added constraints, must restart analysis from fill+pack+warp+stress
  • stress analysis is supported in midplane only
If you have valid license, try to reach local Autodesk support team with your details of objective to run such analysis
Madhukeshwar Talwar
FORD MOTORS PRIVATE LIMITED, Chennai
mail: madhukeshwart@gmail.com
09600060862
Please use . Accept as Solution and Give Kudos as appropriate to further enhance these forums. Thank you! .....
