connectivity region
connectivity region
nbhoopat
Message 1 of 11
connectivity region
nbhoopat
Hi ,
For a Midplane -Two cavity part (LH & RH) reflected  part with cooling channel (core & cavity cooling ) i am getting connectivity region 4 , which is weird,
i have checked every parameter for mesh quality, cooling quality, feed system , every thing is perfect  with single region . mesh orientation as well as overlapping intersection (none observed) are as as per moldflow  criteria.
Version used and checked  Moldflow 2016 & 2017 .
Thanks in Advance
Arvind.
Thanks in advance
Arvind B
Replies (10)
Message 2 of 11
mppkumar
Hi
M P Pradeep Kumar
If my views / comments acceptable, provide "Kudos" as appreciation, if answers your query, please click the "Accept as Solution"
Message 3 of 11
nbhoopat
 Hi ,
i have  two cooling layout (straight line cooling ) core and cavity with 5 inlets and feed connected with part so practically i should get 3 connectivity regions.
so can you help me with this ,
thanks
Thanks in advance
Arvind B
Message 4 of 11
mppkumar
Hi
M P Pradeep Kumar
Message 5 of 11
nbhoopat
 Hi ji ,
For checking duplicate elements and short length in feed system and cooling channel we use beam elements to find , but for overall i use triangle to find mesh statistics.
Thanks in advance
Arvind B
Message 6 of 11
mppkumar
Hi
If triangle element is used, then it should have connectivity as 1
M P Pradeep Kumar
Message 7 of 11
nbhoopat
For only cooling channels it shows 11 connectivity regions ( Total of 5 inlet in both core cooling and cavity cooling ) straight line cooling
Thanks in advance
Arvind B
Message 8 of 11
bernor_mf
Hi Arvind,
read the thread and strange things you experience.
1) If you roll back to original LH + cooling circuit does connectivity look ok?
2) Just for the troubleshooting: export the LH+RH to patran format, re-import the patran file.
What does connectivity looks like?
3) Contact Autodesk technical support...
I think I have seen something similar to this on Midplane mesh in some releases back, but memory is a bit weak here...
Could not find any article on the issue, so might be before article publishing started.
Berndt
( If my comments are accepted, provide "Kudos" as appreciation. If your request is answered/resolved, please click the "Accept as Solution" button. Thanks.)
Message 9 of 11
mppkumar
Hi
Beams connectivity regions, what you are getting is correct (11 regions)
This includes 5 core side cooling + 5 cavity side cooling + 1 feed system = 11 regions
you need to cross check the meshed model
if possible share the FE model to me
M P Pradeep Kumar
Message 10 of 11
nbhoopat
Hi ,
yes Actually 11 regions is correct including beam , there is some problem in mesh .
Arvind
Thanks in advance
Arvind B
Message 11 of 11
nbhoopat
Hi ,
After  exporting mesh to patran file ,still same connectivity problem exist but yes now i can find that there are some 3 Different Part_Surface (mid plane).
So now i can find on which area mesh needs to be improved
Thanks !!
Thanks in advance
Arvind B
