Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Cartridge heater for cooling.
praphotSYZN3
praphotSYZN3
Hi Everyone
I have some problem about cartridge convert to cooling? For answer to true from flow analysis.
1.What kind of mesh should I use?
 1.1 Dual Domain
 1.2 3D
2.How to I setting parameter for cartridge heater properties?
3.Why temperature not same? and where I should adjust?
4.Cartridge heater could I used beam element type?
madhukeshwart
it can be used for both Dual domain & 3D
click on cartridge element and check properties
set in properties only
yes
Madhukeshwar Talwar
FORD MOTORS PRIVATE LIMITED, Chennai
mail: madhukeshwart@gmail.com
09600060862
Please use . Accept as Solution and Give Kudos as appropriate to further enhance these forums. Thank you! .....
